sparky
Posted: Fri Jan 28, 2011 11:51 am Post subject: Alternator Mountings |
Hey guys,
Need help identifiying a part
The top bolt on the alternator goes through the 2 brackets mounted onto the block. On those 2 brackets there are metal sleeves with what im guessing use to have some kind of rubber around them to centre the bolts.
Mine have worn or perished so my alternator is sitting lob sided.
Does anyone have a part number for these bits, or their name?
Or well, any other car that uses them? Or a suggested fix for this..
Cheers all  _________________ When the checkered flag drops... The Bull$hit Stops
1976 Euro 924 (The 945) - Full 951 Brakes/Suspension
1998 Boxster with goodies
2002 3.0 Xtype 4wd sport |
sparky
Posted: Fri Jan 28, 2011 9:45 pm Post subject: |
Ok done
The upper alternator mount has 2 sleeves and a rubber that slips over them. The rubbers had both perished and fallen out, part number for future reference of the rubbers is: 059 903 263
No one had the rubber on the island so if you want to make your own:
Get a 10c euro coin, some thick 1cm~thick hard rubber, cut a circle the size of the 10c coin, sand it down until it just squeeze into the hole, make a hole in the middle so it just fits over the sleeve, squeeze it back into the hole with the sleeve and job done, you will need to sand it down a little more and then tap it into place. Hope this helps someone one day when doing a search..
Enjoy  _________________ When the checkered flag drops... The Bull$hit Stops
Ozzie
Posted: Fri Jan 28, 2011 11:35 pm Post subject: |
I just used some poly bushes from a toyota 4x4 suspension.
fitted straight in. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
gohim
Posted: Sun Jan 30, 2011 8:07 pm Post subject: |
Porsche superceeded the rubber bushings to poly over 20 years ago. Local auto part stores here were still selling the rubber version last time I checked.
The rubber bushing didn't last long or wear well. The poly ones are truely a PITA to install, but they last forever. I've never replaced any of the poly bushings after I switched them on my 924s. and I have some that are over 20 years old in my 81 924. |
sparky
Posted: Tue Feb 01, 2011 2:54 am Post subject: |
Sorry for the bump, sigh, I see why hard rubber was superceeded..
Ozzie, which model/year Toyota 4x4 suspension bushings did you use? Ill be picking some up tomorrow from the local Toyota dealer  _________________ When the checkered flag drops... The Bull$hit Stops
Ozzie
Posted: Tue Feb 01, 2011 7:43 am Post subject: |
I forget as it was a while back.
take what is left of your old ones with you. _________________ Porsche 924 1984 (UK import) NA
Jakkq
Joined: 29 Sep 2008 Posts: 810 Location: Omaha, Nebraska
Posted: Tue Feb 08, 2011 12:53 pm Post subject: |
I actually have some rubber mounts that Tom had given me. My problem right now enough is the alternator brackets. I have not been able to find any online, but once my garage gets cleaned I am going to take a look and see if I can make a homeade reokacent, or take the brackets off, and see about getting some manufactured. _________________ 1979 Porsche 924- Snailshell
http://porsche924workblog.blogspot.com/ |
Posted: Tue Feb 08, 2011 1:16 pm Post subject: |
I got mine from a german shop here in the states.
Complete kit for round 20 us dollars. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
jamis1970
Joined: 08 Oct 2010 Posts: 56 Location: big bear lake 92315
Posted: Tue Feb 08, 2011 2:10 pm Post subject: alt bushings |
I went to napa and found the rubber bushings for 3 bucks for a set of four. Bring the metal insert that the bushings go on. they have a rack full of misc grommets and I found a set that fit perfect. I was very excited. had alt remounted in 20 min. _________________ 1979 924 N/A Not Fast, but a BLAST to drive. |
Posted: Wed Feb 09, 2011 2:53 am Post subject: |
that was a few yeas ago. Ive been asked if I still
have the hook for these. It came with the cupped
washers and inner sleeve. Time to give them a call.
Posted: Wed Feb 09, 2011 3:54 am Post subject: |
Darn out of the 3 part numbers listed all i can get is the 19 mm
bushing. _________________ 1979 porsche 924 Na
Jakkq
Posted: Thu Jun 02, 2011 9:38 am Post subject: |
Has anyone found fittable bushings that are NOT rubber?
It seems as though any oil that gets on these deteriorates them. _________________ 1979 Porsche 924- Snailshell
Posted: Thu Jun 02, 2011 1:42 pm Post subject: |
| Jakkq wrote: | Has anyone found fittable bushings that are NOT rubber?
It seems as though any oil that gets on these deteriorates them. |
Fix your oil leaks
Seriously, measure the ID and the OD needed and order some generic PolyBushings from here:
http://polybushings.com/pages/bushingsbysize.html _________________ Stefan
Ozzie
Posted: Thu Jun 02, 2011 6:27 pm Post subject: |
If I had a lathe I'd turn up some ally. _________________ Porsche 924 1984 (UK import) NA
Jakkq
Posted: Fri Jun 03, 2011 1:18 pm Post subject: |
| fiat22turbo wrote: | | Jakkq wrote: | Has anyone found fittable bushings that are NOT rubber?
Fix your oil leaks
http://polybushings.com/pages/bushingsbysize.html |
Except my rubber bushings are all decomposed, and I honestly don't know what the original sizes or thickness of them are. _________________ 1979 Porsche 924- Snailshell
