Porver9two4
Joined: 22 Jan 2004 Posts: 104 Location: United Kingdom
Posted: Wed Jan 26, 2011 11:28 pm Post subject: setting 924 ignition timing and marks |
I want to check the ignition timing is right on my 924 - can someone give me the right procedure and settings (or where the marks are) please? I had a quick search but didn't find anything.
Is it done with vacuum hose on or off?
Basically mine runs fine, but can be a bit*h to start! It sorta kicks back on the starter, almost as if the firing stroke wants to reverse the direction of the engine when engaging the starter. It isn't the starter thats had it either, as it turns over fine with the ignition disconnected..... Having had cars before that have done similar when the ignition timing was out, I want to check it thoroughly to make sure it is spot on.  |
emoore924
Posted: Thu Jan 27, 2011 3:27 am Post subject: |
easiest way to set static timing is this:
Line up three things:
1) Edge of rotor in distributor with small hash mark on rim of distributor (need to remove cap to see mark in rim)
2) Dot on *rear* of cam pulley with pointer on valve cover
3) Mark on crank pulley with pointer on block |
Porver9two4
Posted: Thu Jan 27, 2011 11:57 pm Post subject: |
OK, thank you.
With static timing set close enough - how do you set the dynamic timing with a strobe light? where are the marks and what to do with vaccum hose? |
rkn
Posted: Fri Jan 28, 2011 5:56 am Post subject: |
Timing/vacuum hose varies, you need to post year/model of your car.
If yours is a post-1980 Euro (possibly earlier models as well, I am not sure), then you want 10 degrees BTDC, vacuum line off.
Marks are on the flywheel, visible through the small window - see below. The marks line up with the L-shaped notch in the window.
There are 3 marks (-10) (0) (+10). I can't remember if it's -10 or +10 you want, but first find the center mark (0), then turn engine counter-clockwise until the next mark appears in the window. This is the mark you use.
 _________________ 1980 924NA ROW |
Porver9two4
Posted: Fri Jan 28, 2011 5:43 pm Post subject: |
Mine is a standard 1984 normally aspirated 924 with a single vaccum connection to the dizzy.
Thanks for the post above, I will have a look for the marks in the window and see what comes up - then set to 10deg BTDC, vaccum line off (and plugged?) |
Porver9two4
Posted: Wed Feb 09, 2011 10:38 pm Post subject: |
Job done thanks for the pointers - found the marks and set it with a timing light.... it was slightly off. Will see how it behaves going forward. |
