Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Sat Jul 10, 2010 1:41 am Post subject: Lower engine temperature by modifying bonnet |
If you read this:
http://maverick-924turbopch.com/
They say the temperature dropped with 22 degrees.
I am building a top mount intercooler Carrera GT style. Using a GT hood scoop.
It will drag cold air on to the intercooler, but the hot air can't get out. Has anybody thought about putting a vent next to the hood scoop to let hot air out?
Or is there a better way to get the hot air out? I don't care much for the looks, its for my race car. _________________ 937 trackday car
Last edited by Dutch924-racer on Sat Jul 10, 2010 3:14 am; edited 1 time in total |
Posted: Sat Jul 10, 2010 1:58 am Post subject: |
That's an interesting car for sure!
Regarding the exit for the CGT intercooler, it has to flow down and out under the RHS footwell. The lower belly pan assists with this, as it has the reverse of those hood vents on the bottom of the pan. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat Jul 10, 2010 2:07 am Post subject: |
Yea you never kept up on your original post on your project ..How is it goin..do you want to give up some pictures, Id like to see. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Sat Jul 10, 2010 3:16 am Post subject: |
| ideola wrote: | That's an interesting car for sure!
Regarding the exit for the CGT intercooler, it has to flow down and out under the RHS footwell. The lower belly pan assists with this, as it has the reverse of those hood vents on the bottom of the pan. |
Never had the belly pan on the car, but that might be a good idea. _________________ 937 trackday car
Posted: Sat Jul 10, 2010 3:17 am Post subject: |
| Joes924Racer wrote: | | Yea you never kept up on your original post on your project ..How is it goin..do you want to give up some pictures, Id like to see. | .
Intercooler project is almost finished, I am waiting on some taps to finish it. I will post pictures when finished. _________________ 937 trackday car
Posted: Sat Jul 10, 2010 5:55 am Post subject: |
| Dutch924-racer wrote: | | ideola wrote: | That's an interesting car for sure!
Never had the belly pan on the car, but that might be a good idea. |
i would be careful with that, probably better flow without, the pressure under the car is lower and thus sucking the air by itself. My friend got severly lower oil temp on his n/a by removing that panel. _________________ 1980 924 Turbo
Posted: Sat Jul 10, 2010 6:30 am Post subject: |
I have 3 turbo cars, and none have a belly pan. Fall off on the road somewhere? The 924S I had, had one though. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Sat Jul 10, 2010 6:33 am Post subject: |
That link says:
| Quote: | | The ASAP PCH featured a hand modified louvered functional hood that dropped engine temperatures 22 degrees |
I say that if that is the case then there must be some serious problem with the cooling system.
Now under hood temp drop sounds feasible. 22* F, WTF is that in real measurements? Have to convert but how? The stupid F unit of measurement is not linear but relative.
http://www.csgnetwork.com/tempconv.html
Regardless of where and how was that quantified, just under the hood must be the most inefficient location possible for an intercooler.
Its also satisfying knowing my slushbox will do it in a 0-60MPH.
Posted: Sat Jul 10, 2010 9:50 am Post subject: |
Wow, is it just me or is that car kinda ugly?
Louvered hood? What is this a hot rod? Did someone get a new louver making machine and decide to practice on the car? Don't get me wrong, they work.
I think in the long run, they'd have been better off using a fiberglass hood and building a single reverse scoop to help direct the air flow through the radiator, intercooler and oil cooler. Less weight and less labor.
Nice work on the bodywork, very smooth and good quality paint. Though why did they leave the repeaters on the front and quasi-french them in?
I will say that the power numbers are impressive and I do like the wheel choice. I wish there were some pictures of the engine bay and the interior though.
As to the original question, I would say that I think it was simsport who had tested and implemented a reverse hood scoop on his car to good effect. Basically, instead of a bunch of smaller louvers, he made one large one just aft of the headlights. _________________ Stefan
931Owner
Joined: 14 Feb 2009 Posts: 352 Location: Chicago NW Suburbs
Posted: Sat Jul 10, 2010 11:16 am Post subject: |
| fiat22turbo wrote: | | Wow, is it just me or is that car kinda ugly? |
It got beat with an ugly stick it did, how else could you make all those holes?
As for the belly pan it helps with the drag co-efficient. Removing the pan produces more turbulent air under the car causing more drag. You will notice higher fuel consumption as well.
The Fiat 600 underneath is nearly flat the whole length of the car and it is one of the contributing factors as to why the 600 based Abarths (my picture) beat the Mini Cooper so often. You will notice many of the new performance cars with a flat underbelly and louvers or channels to assist air movement.
I also noticed on the A6 an increase in fuel consumption without the belly pan on trips, so I put it back on.
Luckily, my 931 was complete, and it still has it's belly pan and timing belt covers. That darn belly pan was a PITA to remove though with rusted bolds and a bent lip on the lower valance. _________________ 1980 Turbo
-too many cars and too many motobikes |
Posted: Sat Jul 10, 2010 11:27 am Post subject: |
| fiat22turbo wrote: | | As to the original question, I would say that I think it was simsport who had tested and implemented a reverse hood scoop on his car to good effect. Basically, instead of a bunch of smaller louvers, he made one large one just aft of the headlights. |
You may be thinking of Steve Bassington's car, which was specifically set up as a low pressure duct for the intercooler, not quite the same intended effect as these louvers, which are designed to evacuate heat from the engine bay.
Steve's car:
Simon's car:
Posted: Sat Jul 10, 2010 5:07 pm Post subject: |
I know Steve's car, but never seen Simon's car. Any more info/ pictures on that 931 racer ? _________________ 937 trackday car
Posted: Sat Jul 10, 2010 9:59 pm Post subject: |
| Dutch924-racer wrote: | | I know Steve's car, but never seen Simon's car. Any more info/ pictures on that 931 racer ? |
Simon = simsport. I'm sure you've seen his car before. Here's an album full of pix:
http://picasaweb.google.com/streetlegalporsche/SimsportSSuperCharged924# _________________ erstwhile owner of just about every 924 variant ever made |
avaconirl
Posted: Sat Jul 10, 2010 11:03 pm Post subject: |
To help the cooling under the bonnet and to use the aerodynamics to help pull out the air but keeping the smooth look of the car.
Remove the scuttle at the battery and on the opposite side of the heater fan. Create new walls on the left and right of the fan so there are no fumes from the engine to the fan.
As the wind passes over the gap between the back of the hood and the lower section of the windscreen it creates a vacuam drawing the hot air from the engine bay.
If you do not want to remove the whole wall then drill large holes in the scuttle maybe 1 1/2 "or 2 |
