Lower engine temperature by modifying bonnet
PostPosted: Sat Jul 10, 2010 1:41 am    Post subject: Lower engine temperature by modifying bonnet Reply with quote
If you read this:
http://maverick-924turbopch.com/
They say the temperature dropped with 22 degrees.
I am building a top mount intercooler Carrera GT style. Using a GT hood scoop.
It will drag cold air on to the intercooler, but the hot air can't get out. Has anybody thought about putting a vent next to the hood scoop to let hot air out?
Or is there a better way to get the hot air out? I don't care much for the looks, its for my race car.
PostPosted: Sat Jul 10, 2010 1:58 am    Post subject: Reply with quote
That's an interesting car for sure!
Regarding the exit for the CGT intercooler, it has to flow down and out under the RHS footwell. The lower belly pan assists with this, as it has the reverse of those hood vents on the bottom of the pan.
PostPosted: Sat Jul 10, 2010 2:07 am    Post subject: Reply with quote
Yea you never kept up on your original post on your project ..How is it goin..do you want to give up some pictures, Id like to see.
PostPosted: Sat Jul 10, 2010 3:16 am    Post subject: Reply with quote
Never had the belly pan on the car, but that might be a good idea.
PostPosted: Sat Jul 10, 2010 3:17 am    Post subject: Reply with quote
Intercooler project is almost finished, I am waiting on some taps to finish it. I will post pictures when finished.
PostPosted: Sat Jul 10, 2010 5:55 am    Post subject: Reply with quote
i would be careful with that, probably better flow without, the pressure under the car is lower and thus sucking the air by itself. My friend got severly lower oil temp on his n/a by removing that panel.
PostPosted: Sat Jul 10, 2010 6:30 am    Post subject: Reply with quote
I have 3 turbo cars, and none have a belly pan. Fall off on the road somewhere? The 924S I had, had one though.
PostPosted: Sat Jul 10, 2010 6:33 am    Post subject: Reply with quote
That link says:
The ASAP PCH featured a hand modified louvered functional hood that dropped engine temperatures 22 degrees
I say that if that is the case then there must be some serious problem with the cooling system.
Now under hood temp drop sounds feasible. 22* F, WTF is that in real measurements? Have to convert but how? The stupid F unit of measurement is not linear but relative.
http://www.csgnetwork.com/tempconv.html
Regardless of where and how was that quantified, just under the hood must be the most inefficient location possible for an intercooler.
Its also satisfying knowing my slushbox will do it in a 0-60MPH.
PostPosted: Sat Jul 10, 2010 9:50 am    Post subject: Reply with quote
Wow, is it just me or is that car kinda ugly?
Louvered hood? What is this a hot rod? Did someone get a new louver making machine and decide to practice on the car? Don't get me wrong, they work.
I think in the long run, they'd have been better off using a fiberglass hood and building a single reverse scoop to help direct the air flow through the radiator, intercooler and oil cooler. Less weight and less labor.
Nice work on the bodywork, very smooth and good quality paint. Though why did they leave the repeaters on the front and quasi-french them in?
I will say that the power numbers are impressive and I do like the wheel choice. I wish there were some pictures of the engine bay and the interior though.
As to the original question, I would say that I think it was simsport who had tested and implemented a reverse hood scoop on his car to good effect. Basically, instead of a bunch of smaller louvers, he made one large one just aft of the headlights.
931Owner
PostPosted: Sat Jul 10, 2010 11:16 am    Post subject: Reply with quote
It got beat with an ugly stick it did, how else could you make all those holes?
As for the belly pan it helps with the drag co-efficient. Removing the pan produces more turbulent air under the car causing more drag. You will notice higher fuel consumption as well.
The Fiat 600 underneath is nearly flat the whole length of the car and it is one of the contributing factors as to why the 600 based Abarths (my picture) beat the Mini Cooper so often. You will notice many of the new performance cars with a flat underbelly and louvers or channels to assist air movement.
I also noticed on the A6 an increase in fuel consumption without the belly pan on trips, so I put it back on.
Luckily, my 931 was complete, and it still has it's belly pan and timing belt covers. That darn belly pan was a PITA to remove though with rusted bolds and a bent lip on the lower valance.
1980 Turbo
PostPosted: Sat Jul 10, 2010 11:27 am    Post subject: Reply with quote
You may be thinking of Steve Bassington's car, which was specifically set up as a low pressure duct for the intercooler, not quite the same intended effect as these louvers, which are designed to evacuate heat from the engine bay.
Steve's car:
Simon's car:
PostPosted: Sat Jul 10, 2010 5:07 pm    Post subject: Reply with quote
I know Steve's car, but never seen Simon's car. Any more info/ pictures on that 931 racer ?
PostPosted: Sat Jul 10, 2010 9:59 pm    Post subject: Reply with quote
Simon = simsport. I'm sure you've seen his car before. Here's an album full of pix:
http://picasaweb.google.com/streetlegalporsche/SimsportSSuperCharged924#
avaconirl
PostPosted: Sat Jul 10, 2010 11:03 pm    Post subject: Reply with quote
To help the cooling under the bonnet and to use the aerodynamics to help pull out the air but keeping the smooth look of the car.
Remove the scuttle at the battery and on the opposite side of the heater fan. Create new walls on the left and right of the fan so there are no fumes from the engine to the fan.
As the wind passes over the gap between the back of the hood and the lower section of the windscreen it creates a vacuam drawing the hot air from the engine bay.
If you do not want to remove the whole wall then drill large holes in the scuttle maybe 1 1/2 "or 2
