Variable Length Intake Runners
Goto page Previous  1, 2, 3, 4, 5, 6
PostPosted: Sat Apr 24, 2010 6:28 am    Post subject: Reply with quote
I was just pointing out that for a turbo it isn't a great area of gain for the cost and weight penalty. I don't think I have ever seen it done on a turbo either (??) The short intake comment on my part was to eliminate lag hence my little comment about the intercooler. The velocity comment was related to short exhaust tubing from head to turbo which keeps things hot and exhaust velocity high to spin the turbo.
Not that I don't want to discourage or see this built for testing, I do. I love this kind of stuff.
Insane
PostPosted: Fri Jul 09, 2010 1:53 am    Post subject: Reply with quote
It seems there is a simple solution:
PostPosted: Fri Jul 09, 2010 2:05 am    Post subject: Reply with quote
Doesn't look simple
How about some details? What application is this from? How does it work? The sliders appear to be on the opposite side, and can't make out how they're attached or how they impact the airflow.
Insane
PostPosted: Fri Jul 09, 2010 2:27 am    Post subject: Reply with quote
This is fro yamaha R6
Already showcased on last year's R1, the 2008 R6 utilizes the Yamaha Chip Controlled Intake (YCC-I) system, which features variable-length intake trumpets that fluctuate dependant on RPM
they use ecu for that but I believe this can be done in more simple way.
Mechanics as I understand it:
individual TB with splitted stepped diameter runners inserted one in another and sealed. They should be straight. And the spring for tension in one of directions.
that's simple.
Another thing which is more complicated is the mechanism which will actually change inner runner position:
mechanically this can be either a motor or a pneumatic system.
In case of a motor you can use something like 924 headlight mechanism controlled with tacho signal (like a shift light).
You can take 10 shiftlight controllers and set them for different RPM - then you'll need a 10 step motor.
here is related topic http://www.f1technical.net/forum/viewtopic.php?f=3&t=1740
and a post from the man who have done it
http://www.auto-teknix.co.uk/Race_Elise.html
more yamaha photos
http://www.sportrider.com/bikes/146_0907_2010_aprilia_rsv4_factory/photo_07.html
Insane
PostPosted: Fri Jul 09, 2010 2:35 am    Post subject: Reply with quote
sorry. first pic was from mazda lemans car r26r
PostPosted: Fri Jul 09, 2010 3:14 am    Post subject: Reply with quote
that's simple.
more yamaha photos
Why not use a micro-controller? Use the tach signal as you say and a small servo? The sky is the limit here. Would be neat to see more of a motorcycle variable system in its different states.
Insane
PostPosted: Fri Jul 09, 2010 4:05 am    Post subject: Reply with quote
cause I know nothing about micro-controllers but I believe it's the best way to go.
PostPosted: Fri Jul 09, 2010 4:39 am    Post subject: Reply with quote
...and we need the system $$$
Those are good pics. Lots of huh, that's what they are doing.
We need those heads too Check out the intake runner
Insane
PostPosted: Fri Jul 09, 2010 6:30 am    Post subject: Reply with quote
Mazda pics
http://www.fd3s.net/787B/26b_1.jpg
http://www.fd3s.net/787B/26b_large.jpg
1 more Moto info
http://www.asphaltandrubber.com/news/rsv4-to-have-variable-throttle-bodies/
Some strange idea I didn't really get
http://www.motorcycle.com/gallery/gallery.php/v/main/reviews/2009-kawasaki-zx-69-review/2009_Kawasaki_ZX6R_ZX600R_09_INTAKE_FUNNELS.jpg.html?g2_GALLERYSID=TMP_SESSION_ID_DI_NOISSES_PMT
PostPosted: Fri Jul 09, 2010 8:24 am    Post subject: Reply with quote
These are fascinating!
Rich H
PostPosted: Fri Jul 09, 2010 8:32 am    Post subject: Reply with quote
Interesting concept, as the inlet speed increases the intake dynamics change
Insane
PostPosted: Fri Jul 09, 2010 4:07 pm    Post subject: Reply with quote
[quote="ideola"]
how does it work?
Rich H
PostPosted: Fri Jul 09, 2010 4:52 pm    Post subject: Reply with quote
I would assume that at high revs/vacuum the airflow is drawn from both the upper larger inlet and the lower smaller lip giving large short air flow.
At lower revs/vacuum the airflow would tend to follow a straighter track giving a smaller effective area and increasing flow speed giving more torque. There will be a degree of contrainment trading airspeed for volume as air is drawn from the lower lip.
How effective it would be compared with an active system, I'd be a bit suspect in practice, there is likely to be a bit of fun and games around the change over between the regimes. But I'm no aerodynamacist!
Page 6 of 6
