dreamgts
Posted: Sat Feb 13, 2010 3:52 am Post subject: |
Well noted RC. I will look into that alt. If it fits like I described I guess its ok then. Did you say I need the 931 AC bracket or a fabricated one? What about the remote sensing/ stop charging , does this involve an exterior switch off of some kind being fitted or does the regulator have some kind of setting to cut off charging? I know nothing zip zero about electrics and how alternators work The idea of switching off when not needed to gain a bit of HP makes it a good alternative I guess. Iv tried a lot of searching on the alternator mod but till now nothing came up regarding fitting an alternative alternator.
thanks
dreamgts _________________ 2 PORSCHE 924 (CURRENT PROJECTS)
2 CLASSIC CORTINAS (FINISHED)
1 CLASSIC FIAT(FINISHED)
1 CLASSIC FIAT 132 2000CC(JUST PURCHASED)
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
dreamgts
Posted: Sun Feb 14, 2010 10:10 pm Post subject: |
This morning I managed to talk to my exhaust guy regarding the exhaust fabrication. After showing him some pics of some exhausts sent on this thread and telling him that other mods will have to be done to make it fit, he wanted to see the space available on the car itself.
During his visit he told me that the header can be done, but he told me that he might have another solution and avoid other alterations and stick with the standard exhaust header. He added that with the mods I have in mind he understands the need for a race exhaust but he also added that the standard exhaust might be modified in a way that it will have minimum affect on loss of BHP and back pressure which seems to be the main concern here.
After inspecting the standard header he told me that it could be partly polished and smoothened from the inside thus in his words making the flow of exhaust better. He also told me that since the distance from the exhaust ports to the first down pipe is short he suggested what he called a 4 to 2 setupusing appropriate sized piping. the downpipe from header to end which will be right up to the right hand side of the car just before the rear wheel( or somewhere close to that) will be totally made of stainless steel. He explained to me that since not much bends are needed to make a short type racing exhaust , this would be possible with stainless steel piping. He told me that I cannot have anything smoother than this material for and exhaust system. He informed me that by using the standard header I might loose some BHP but not that much. He also offered that he might like to experiment on this system for the 924 and was willing to charge me only for the stainless steel piping needed. What do you guys think of this? It kind of made sense to me since it would eliminate much concern although I would still go for the remote oil filter set up and change of alternator to a lighter unit, yet this would be left in its original position in order not to spoil the look of the 45 DCOE as seen on Franks car. This way a sure fit of all units is kind of gauranteed
thanks
dreamgts
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Posted: Sun Feb 14, 2010 10:36 pm Post subject: |
Sounds like a reasonable compromise to me.
If you really want to do what Frank did, you could always move the alt to the rear axle...
...here's my solution:
http://www.924board.org/viewtopic.php?t=29518 _________________ erstwhile owner of just about every 924 variant ever made |
dreamgts
Posted: Sun Feb 14, 2010 11:01 pm Post subject: |
To be honest this guy knows what to do, he is the Maltese exhaust man. He knows me very well since i took many a customer to him when he was starting out. He does not like a header with a lot of welds and cuts in them for his own reason. I also think it is very a reasonable alternative so I am considering going this way. i think 2 tail pipes at the end will look nice too, he wants to go this way to keep flow from the exhaust in the same pipes.
Regarding the alternator, Iv seen yours and it looks very pro and racy too, though a lot of engineering work seems to go with the install. May I also ask what are the plus's with this install, and it also seems that I would have to cut out some rear metal panelling and removing the fuel tank/ installing afuel cell etc to this, which are not in mind and in the project at the moment. I am sure that by removing the alternator to ths position certain power taken from the engine to spin the alt will be saved therefore meaning + BHP. Right??
Thanks
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Posted: Tue Feb 16, 2010 1:47 am Post subject: |
| dreamgts wrote: | Well noted RC. I will look into that alt. If it fits like I described I guess its ok then. Did you say I need the 931 AC bracket or a fabricated one? What about the remote sensing/ stop charging , does this involve an exterior switch off of some kind being fitted or does the regulator have some kind of setting to cut off charging? I know nothing zip zero about electrics and how alternators work The idea of switching off when not needed to gain a bit of HP makes it a good alternative I guess. Iv tried a lot of searching on the alternator mod but till now nothing came up regarding fitting an alternative alternator.
thanks
dreamgts |
I didn`t say you need a 931 bracket at all. The CS130D is similar size to stock and the mounting spool similar width so it CAN BE MADE to fit in NA or 931 location fairly easily. Any other position will require some type of mounting bracket.
In addition to the B+ (big main battery) terminal it has a 4 pin connector with different functions. It can easily be wired same as the stock unit with idiot light. Other pins allow for remote sensing and/ or switching. Simple for an electrician to wire a manual switch but would suggest a WOT switch or similar. In my case it will eventually be linked to my ECU and programmed to cut at a certain throttle %, RPM, or whatever I want.
There is no need to change alternators if using a ported stock manifold, or indeed even with headers. More details and wiring diagram is easy found via google and I`m willing to help if you decide to go that way. May even post details and pics if many are interested in the swap.
You know, the stock cast exhaust manifold isn`t really that bad, certainly as far as OEM manifolds go. Essentially a 4-2-1 anyway. Headers do not make 25% more power like some sellers advertise and certainly not more than 5% on these NA motors. Search and read the board as others have fitted headers to an otherwise stock motor and been disappointed with the results. While it may give 5 HP more at 6K you will likely lose that at 3K, where the motor spends more time and has much less power anyway. Even for racing the low & mid range loss may not make up for the top end, particularly on small tight tracks & hillclimbs. |
dreamgts
Posted: Tue Feb 16, 2010 3:57 am Post subject: |
Thanks RC for this info. I have decided to go for the modified standard header and stainless steel exhaust system, We can always try obtaining any minor loss in BHP by going this way with other mods to the engine.
As for the alternator, I have seen a pic posted by Cedric on my thread regarding 70's style wheels which shows an alternator on a 924 which is fitted very low beneath the throttle bodies, actually it hardly shows,so if I want to change position i am sure that it can be done also.
I like the idea of fitting the CS130D since as you say it can be modified to cut charging. We will have to investigate how we can connect this to a 'cut off' switch , I havnt decided on ignition system yet maybe I could find a system to which the alternator pin can be connected to and as you say cuts off power at a certain rpm. I think that the local GM agent can source this locally.
Basically I am looking for power for tight tracks and hill climb events so whatever is done has to produce power in a short distance. i have had no trouble with other makes of car achieving this since we used low geared gearboxs, and diffs with Limited slip as well as being low geared, smaller diamter tyres also helped to achiev speed in short ditances , but as I said these were other makes and not 924, I am still to experience a modified 924, Im sure I wont be disapointed. I also read on some threads that we 924 people tend to go for cheap stuff or are some sort of bargain hunters, I totally do not agree with this since sourcing parts cheaply if possible in my view means that a person is capable of doing so. For example I cannot source a donor car for lets say $ 1000 here In Malta But if I could I would, I dont think that would make me cheap. I have seen some nice set ups on the forum and all seem to have cost $$$$$. And in any case whats wrong with doing a bargain in these days where cash flow is tight.
Thanks
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Min
Posted: Thu Feb 18, 2010 1:55 pm Post subject: |
My buddy found this little goodie while looking around on summit. http://www.summitracing.com/parts/CTR-22-595/ can rotate it to any angle and then tighten it back up. A bit more expensive than the transdapt item though.
dreamgts
Posted: Thu Feb 18, 2010 10:42 pm Post subject: |
Min, that adaptor seems to be a good item since it rotates, does it fit the threading of the 924NA? I think I think that the threads mentioned are the same but im not sure. OOOps gave a closer look yes they do 3/4 X 16. nice interesting item.
Thanks
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Min
Posted: Fri Feb 19, 2010 5:22 am Post subject: |
The item posted should be the correct item for a 924, the sealing surface is also in the right place. If not they do have a variety of other threads available.
924OZY
Joined: 24 Jan 2010 Posts: 71 Location: Gold Coast Australia
Posted: Fri Feb 26, 2010 1:52 am Post subject: |
If you do go a twin system, the theory is there are two paths and that should halve the restriction.
Its correct if the pipe diameter is the same as the single was.
But there is also a thing called a crossover pipe that balances the pressure of both pipes. These can gain up to 10%+ power at the wheels over a twin system without one.
Going over twin 2and a quarter inch pipes would lose a lot down low.
Its about the same CFM as a single 2.5inch.
With regards to the crossover pipe,
A good length is about 10 inches long.
Basically a the two pipes must be next to eachother and a larger pipe that has been squashed in a vice, to fit over both pipes is welded to the end, a good length for this would be about 10 inches,
longer should work better down low and shorter up top,
like most things to do with pipe length in an exhaust.(they even sell them off the shelf now).
Our Touring cars use them and your Nascars probably do too.  _________________ 924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
4.0L ef Fairmont, 3000rpm stall, shift-kit, J3 chip, 3" exhaust, self tuned using tunerpro, soon to be boosted,
expecting 350Kw at wheels at 10psi. |
