motion vega
Posted: Fri Jan 08, 2010 9:25 am Post subject: ok i got it to run on its own finally.....but u have ?s |
after reading the 6 page vaccum/british vs american pisssing contest i discovered the 3 mm bolt for the cis and gave it a turn and now itll run on its own now heres the questions. im missing the little plug for the adjuster hole on the cis, will that make a tuning difference since its a vacc leak? and is thagt plug available anywhere? question two now that its running the valves click like mad is it possible the lifters are far enough out of adjustment its effecting the vacc signal? also have the oil light comnig on at around 800 rpm, should i be concerned? or should i just change the oil and see what happens? third since imlazy and dont wanna search right now, is there a prefab cage kit for 924s? this is gonna be a 24 hours of lemons car. also im gonna need wheels for it. i heard 4 lug mustang fits true? ideas? _________________ 78 924 pile of donkey droppings that i never should have bought for 400 bucks |
Posted: Fri Jan 08, 2010 10:24 am Post subject: |
The CIS plug doesn't really have much impact on an NA, but definitely on a Turbo. I'm checking on availability of those bits right now, and hope to have an answer by next week. But you could just as easily use a hardware store rubber or cork stopper.
Yes, the lifters almost certainly need adjusting, and if they're out badly, it can affect vacuum. So can ignition timing. So check them both (lifters first).
Re: oil pressure, change the oil and don't use 5W or 10W30. 10W40, 15W50 or 20W50.
Yes, early Mustang wheels have 4x108, but may not have the correct offset.
Prefab cage, the cheapest bolt in version I know of is from AutoPower. _________________ erstwhile owner of just about every 924 variant ever made |
motion vega
Posted: Fri Jan 08, 2010 10:51 am Post subject: |
cool ill look the cage up now. i guess if the plug isnt available i can just toss a drop of rtv on the hole. im gonna look at bart and see if they have a rim inthe right b.s. _________________ 78 924 pile of donkey droppings that i never should have bought for 400 bucks |
Posted: Fri Jan 08, 2010 10:59 am Post subject: |
| motion vega wrote: | | i guess if the plug isnt available i can just toss a drop of rtv on the hole. |
Noooooooo!!! Don't do that, you need access to that to adjust the fuel. Either do nothing, or get a cork or rubber stopper as I suggested for a few pennies at the hardware store. _________________ erstwhile owner of just about every 924 variant ever made |
motion vega
Posted: Fri Jan 08, 2010 11:10 am Post subject: |
duct tape it is. _________________ 78 924 pile of donkey droppings that i never should have bought for 400 bucks |
avaconirl
Posted: Fri Jan 08, 2010 9:28 pm Post subject: |
| As far as i remember on my 924 there is a wheel valve cap on the tube into the cis adj. I hope this helps to all. |
Posted: Fri Jan 08, 2010 9:40 pm Post subject: |
| avaconirl wrote: | | wheel valve cap on the tube into the cis adj. |
Not stock, but effective, I suppose  _________________ erstwhile owner of just about every 924 variant ever made |
stevekat
Joined: 19 Jan 2008 Posts: 719 Location: Los Angeles, CA
Posted: Fri Jan 08, 2010 10:40 pm Post subject: |
regarding your valve noise, there is an elbow that leads to an oil bar, make sure it is properly in place, and not leaking oil pressure. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's. |
joejax
Joined: 02 Dec 2009 Posts: 919 Location: Jacksonville,FLA,USA
motion vega
Posted: Sat Jan 09, 2010 3:34 am Post subject: |
focus looks promising _________________ 78 924 pile of donkey droppings that i never should have bought for 400 bucks |
motion vega
Posted: Sat Jan 09, 2010 3:56 am Post subject: |
to bad all of those are alloy wheels. im lookin for steel _________________ 78 924 pile of donkey droppings that i never should have bought for 400 bucks |
