924 on MS need some help
etiennekuh
PostPosted: Thu Dec 03, 2009 9:30 am    Post subject: 924 on MS need some help Reply with quote
I am trying to tune my 924 N/A with MS.
Now I have some problems, I have a AFR table but I dont think is very good
If some one will check my msq file and give some notes, (I have just started to tune) then sent me a PM with email, and I will sent it.
tuning is like a good hobby, it never gets bored
macBdog
PostPosted: Thu Dec 03, 2009 12:20 pm    Post subject: Reply with quote
Get a wideband. Seriously I tuned my car with MS1 and it was like a guessing game without the wideband.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
Min
PostPosted: Thu Dec 03, 2009 3:04 pm    Post subject: Reply with quote
If you do a bit of searching, I've posted all of my tables for my 924 N/A.
Min
etiennekuh
PostPosted: Thu Dec 03, 2009 4:42 pm    Post subject: Reply with quote
I have a wideband already
ok I will do a search thanks
Etienne
PostPosted: Thu Dec 03, 2009 7:00 pm    Post subject: Reply with quote
Min
Linky link
Min
PostPosted: Fri Dec 04, 2009 1:07 pm    Post subject: Reply with quote
Ah yes, that's a good post, maybe some kindly moderator can sticky it?
Min
Martijnus
PostPosted: Fri Dec 04, 2009 9:38 pm    Post subject: Reply with quote
I've got some tables too, which work just fine at the moment.
The only problem is that I've probably got another setup; raised CR, itb's etc. and therefore running alpha-N instead of the speed density algorithm.
Still, if you'd like some help, let me know. My msn adress is the hotmail adress I specified in my profile.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
etiennekuh
PostPosted: Sun Dec 13, 2009 9:20 am    Post subject: Reply with quote
I have a question
what kind of MAP value are you all running when idling?
I have 59 Kpa...
On the MS site they say 25 is around normal.
My engine idles around 850 rpm
PostPosted: Sun Dec 13, 2009 10:57 am    Post subject: Reply with quote
I'm around high 40s, low 50s. Bigger TB might be causing that. Never been down below 40 at idle for me.
Martijnus
PostPosted: Sun Dec 13, 2009 11:09 am    Post subject: Reply with quote
60 at the moment, measured in a damping box.
I've had it near 50kpa before. Once 45, but that was at the injectors (in head) and not the tb.
Min
PostPosted: Sun Dec 13, 2009 1:12 pm    Post subject: Reply with quote
33 to 35 kpa at idle.
Min
etiennekuh
PostPosted: Sun Dec 13, 2009 9:25 pm    Post subject: Reply with quote
How do I get this down?
Becaus I am trying to set all the injector karateristics
At the moment I am having PWM current limit off 30% and 10ms of opening time, I am trying to change it to 30% and 1.7 ms. And I am changing my REQF form 18 to 13.4.
etiennekuh
PostPosted: Sun Dec 13, 2009 11:43 pm    Post subject: Reply with quote
I have some new problems, I don't get the injector karateristics good
This is what I have
Injector opening time 7.0ms
PWM current limit 40%
Time threshold 4.0ms
PWM periode 66us
Req fuel 19
I have bosch 0280150158 944 injetors (2.9 ohm) 23 lbs
It ilde's at 55 Kpa with a VE of 69. If I gently push the throttle and get it up to 70-75 Kpa Ve is then 77 it leans out.
If i set the timethreshold under 3.7ms it run very bad, so what I thougt, the time threshold must be a bit higher. But the Megamanual says that if your injectors are less then 3ohm your current limit should be around 30% or less and the time threshold 1 ms. And they say it should be more then 1.5-1.7 or your injectors will fry...
so what am I doing wrong??
etiennekuh
PostPosted: Mon Dec 14, 2009 3:46 am    Post subject: Reply with quote
I think I have found a sulution... I have a set of 18lbs high impedance volvo injectors.
That will solve the problem of time threshold and pwm threshold.
What should I use for injector opening time, when I use the high impedance?
Etienne
Min
PostPosted: Mon Dec 14, 2009 5:00 am    Post subject: Reply with quote
Start with 1 millisecond, and get the car running with that, you can't tune it properly until the car is drivable.
Min
