cargo cover missing driver side end cap and spring action
dash16
PostPosted: Wed Sep 09, 2009 2:38 pm    Post subject: cargo cover missing driver side end cap and spring action Reply with quote
doesn't center on one side so it doesn't roll/retract
any suggestions?
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
Vince Ponz
PostPosted: Fri Sep 11, 2009 12:19 am    Post subject: Reply with quote
Pull it out all the way and make sure it rolls back evenly.
You could try to take it apart and rewind.
I have one in brown if you need one.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
Duncan
PostPosted: Fri Sep 11, 2009 5:36 pm    Post subject: Re: cargo cover missing driver side end cap and spring actio Reply with quote
any suggestions?
You can (could?) buy the end caps separately, for something like $2 from the dealer and just pop rivet them back on. I bought a pair like 5 years ago.
Duncan
Andre'
PostPosted: Mon Sep 14, 2009 10:13 am    Post subject: Reply with quote
Easy fix - disassemble, rewind and use pop rivets to reassemble.
dash16
PostPosted: Fri Dec 04, 2009 6:52 am    Post subject: Reply with quote
I already disassembled it. The spring action and cap are missing on out side, causing the roll to snag up.
What I need is both the spring action and cap from the driver side.
STUTTGART PREVAILS
