Joes924 Guest
Posted: Sun Sep 01, 2002 2:43 pm Post subject: |
Ive heard on about packing them with grease
on v-8 then spinning then using a bit in a drill that fits into the slot on the camgear
where the dizzy goes, on the 924 what just pack it with grease.How come the haynes manual doesnt say anything about this.
Joes924 Guest
Posted: Thu Sep 05, 2002 4:50 pm Post subject: |
So anyone want to write something good about priming the oil pump.
JoeD. 1979 924NA
MSD6 rev control/big bore TB/P&P.head
Bursche header/Schneider cam/dialcam
Motor currently in pieces.
[ This Message was edited by: Joes924 on 2002-09-08 12:23 ] |
Joined: 29 Jul 2001 Posts: 9080 Location: Royal Oak, MI, USA
Posted: Thu Sep 05, 2002 10:50 pm Post subject: |
What I did was, as mentioned, pack with vaseline to get it to prime. You can't spin it separately like a Chebbie since it's powered by the crank. You must crank the engine over. Keep the spark plugs out to make it easy on the starter, and crank for short intervals (with a suitable cooling period inbetween to minimize the stress on the starter) until you see pressure at the gauge. Then you can reinstall plugs and wires and try to get it started.
It will take forever to get oil pressure. Don't give up or get frustrated.
Lizard Guest
Posted: Fri Sep 06, 2002 1:20 am Post subject: |
why not have the engine on the engine stand have the oil in it and the vasiline, then hook an impact gun up to the crank and turn the crank around for about 5 min it will get the oil preasure up but make sure the plugs are removed so it can turn easier
Paul Guest
Posted: Fri Sep 06, 2002 8:03 am Post subject: |
I always fill the oil galleys, the oil cooler and lines, and the oil filter.
I also use vaseline in the pump.
Then I crank without the plugs until I see oil being sprayed on the cam. |
Joes924 Guest
Posted: Fri Sep 06, 2002 8:40 am Post subject: |
Yea-gotcha,I packed it then set it on the pins and cranked it over awhile by the nut to see what would happen. then I used a screwdrivwer and stick to pack it in real good I didnt take off the back cover held on with I think six phillups srcews but I did take out the pressure spring and pack that hole. on the back I packed what looked like the outlet or inlet to the block.
Also before I seal it up with the pan shall I or should I cover the crank journals with grease before I set it on the bearings and put on the caps and should I do the same to the rod bearings grease them up. Not with a long lasting lithium just a all purpose grease.[ This Message was edited by: Joes924 on 2002-09-06 08:40 ]
[ This Message was edited by: Joes924 on 2002-09-08 12:28 ] |
Paul Guest
Posted: Fri Sep 06, 2002 10:03 am Post subject: |
I would use assembly lube on the mains, rod bearings and cam bearings, it comes in a large toothpaste tube.
I always dip pistons in a can of oil (sink 'em) before installation. |
Joes924 Guest
Posted: Sat Sep 07, 2002 9:55 am Post subject: |
| light oil like 10-30 |
