9XX Girl!
Joined: 20 Sep 2009 Posts: 1617 Location: Cornish Riviera SW England
Posted: Thu Oct 01, 2009 3:56 am Post subject: |
yer morghen did stpulate | Quote: | | not very expensive |  _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
924 (81) N/A 2 ltr - 3 Speed Auto - SURINAM RED (Metallic) - Near Original Spec (sticking with originality)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY |
9XX Girl!
Posted: Thu Oct 01, 2009 4:01 am Post subject: |
this car has raised rear suspention ???
Posted: Thu Oct 01, 2009 4:37 am Post subject: |
| 9XX Girl! wrote: | yer morghen did stpulate | Quote: | | not very expensive |  |
I know. That's why I think he should forget about rear coil overs. Waste of time and money on a street car in my opinion. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Oct 01, 2009 6:46 am Post subject: |
i think i'd be better off with a set of thicker torsion bars...right now i have the 23mm ones and the car puts the ass down when i leave in a hurry.
take a look here @min 1:35: http://www.youtube.com/watch?v=FFt1WVms2Ms
i was thinking of coilovers for the rear to avoid changing the torsion bars.
9xx Girl check out my signature...my car is preety low i'd say...there would be room for rising it just a tad...however i'll drop the rear coilovers ideea and probably get a set of stiffer torsion bars.
anyway...that 200$ conversion kit for the fronts looks very nice...i think i'm going to get one. _________________ Supercharger and EFI kits
https://www.the924.com |
9XX Girl!
Posted: Thu Oct 01, 2009 7:36 am Post subject: |
yer, i did look into that idea but too much work involved as i would have to drop the rear beam. could not aford the down time as i need the car for work! but makes sence if you got the time _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
Rocco R16V
Posted: Thu Oct 01, 2009 3:15 pm Post subject: |
| ideola wrote: | | You can get replacement Eibach springs in 50# increments, and they're not that expensive for just the spring itself, I think in the range of $60-$70 each. |
actually it 25# up to 550# then 50# increments above that
http://eibach.com/cgi-bin/htmlos.exe/0368.2.4545805536000013301 _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
Posted: Thu Oct 01, 2009 3:57 pm Post subject: |
Why would you get the mookah coilover sleeve kit when you can get teh paragon or ground control sleeve kit for like pennies more? _________________ [This Space For Rent] |
Posted: Thu Oct 01, 2009 5:56 pm Post subject: |
Morghen, the cheapest option by far up front is to buy adjustable spring seats at rallydesign. A friend of mine did that on his 924, workes really nice and you can choose by hundreds of springs.
The kit is 21£ per side, just add springs.
http://www.rallydesign.co.uk/product_info.php?products_id=3450
For my car I bougth 28mm torsion bars from clip1.com, pretty easy to install and gives a pretty stiff car, not at all to stiff of you dont have the dampers set to hard. If you want to get coil overs how about GAZ ? Or maybe AVO. GAZ is the cheapest one.
You wont brake anything with coil overs, race cars run haaaard springs and dampers on those without problems. The loads are way more than a pothole on the street. You havent seen swedish curbs yet  _________________ 1980 924 Turbo
Posted: Thu Oct 01, 2009 7:28 pm Post subject: |
thanks Cédric, i'm not specially looking for the cheapest stuff..but something that will be good and reliable on the street and not godly expensive...as i'm not into racing and i see no reason to throw money on expensive equipment so i can use it on sundays
thanks guys !
i'm going to make a comparison between all the options and see what i'll get. _________________ Supercharger and EFI kits
Shurick
Joined: 15 May 2005 Posts: 524 Location: Russia, Moscow.
Posted: Sat Oct 03, 2009 5:58 pm Post subject: |
Cédric, thanks for the link. Which springs do you have in front with 28 t-bars in the rear? _________________ WBR, Shurick
'86 924S -- R.I.P.
