Searching idle
firemn131
PostPosted: Sat Sep 05, 2009 12:46 pm    Post subject: Searching idle Reply with quote
Hey all.
I recently replaced my Throttle position sensor.
Problems prior to replacement were
Wandering idle. Would hunt between 600 rpm and 1000.
Would stall at a stop
no acceleration unless peddle was nursed.
Changed switch and acceleration is now good, no stalling.
BUT
Idle still wanders and is high
idles steady at 1400. when it is searching it searches from 1200 to 1600.
Could the position of the TPS have increased the idle? The switches come on when they are supposed to.
Idle control sensor/valve?
It used to hum along at 950 rpm so i don't really want to start messing with the idle screw.
Vacuum lines look good
Fuel press Reg fairly new
thnx again
John
1987 924S Daily driver 64 miles each way to work.
2001 F-150 my back up
1970 Mercury Cougar XR7 The Muscle.
edredas
PostPosted: Sat Sep 05, 2009 1:51 pm    Post subject: Reply with quote
Unplug the two vacuum hoses running to the boot. Plug-up those holes with your fingers and have someone start the car... if it runs normally you've either got a bad IAC valve or faulty air/oil separator...
{EDIT} Actually, you just have to unplug the one nearest the manifold... as the other just runs to the manifold and to the brake booster...
'84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
