Rick MacLaren Guest
Posted: Tue Aug 27, 2002 4:44 am Post subject: |
I would NOT run a 931 with old gas lines.
You've got two of them on the passenger side. Remove the clips and have a look underneath the line. Chances are, the line is cracked in more than one spot, especially if it is the original gas line.
Replace them. It's just not worth having a fire.
And don't start using low octane gas. The gas isn't the problem, rather, the problem will eventually be the use of an original rubber part that should've been replaced 10 years ago. |
sneed21 Guest
Posted: Tue Aug 27, 2002 4:52 am Post subject: |
Thanks for the heads up! Guess I better make the time to get "under the car" and run new lines. |
Rick MacLaren Guest
Posted: Tue Aug 27, 2002 5:00 am Post subject: |
You're welcome. I'm talking 931 only now...
Don't even need to be under it. The two relevant lines are right up top, into the fuel distribution unit, held on by I think 17 mm nuts.
931 110 303 01, I think. And 00.
I think the rest of the car gas lines are stainless...or at least steel.
There are a few up top, near the windshield washer area. They're bulletproof. |
sneed21 Guest
Posted: Tue Aug 27, 2002 5:14 am Post subject: |
| Sounds pretty easy..Thats good news. I know the lines run from the windshield to the secondary fuel pump and then to the carbs is new, but the initial run from the fuel tank worries me. I bet it's half dry-rotted and has cracks all along it. |
Lizard Guest
Posted: Tue Aug 27, 2002 6:12 am Post subject: |
there are a few rubber lines under the back I would suggest changing as well
Rick MacLaren Guest
Posted: Tue Aug 27, 2002 6:44 am Post subject: |
| Oh yes...around the fuel pump right rear...!!! They always look like crap too...wouldn't hurt to replace that one. |
John H Guest
Posted: Tue Aug 27, 2002 3:58 pm Post subject: |
| Quote: |
On 2002-08-27 03:43, sneed21 wrote:
I heard that higher octane fuel can damage old gas lines. Is this true, or have I heard wrong?
It's not the octane that damages the lines it's what has been put in the fuel to raise the octane that causes the damage.
What oil companies do to raise the octane rating is add the "aromatics" - touloene is one type of aromatics - these tend to be slightly corrosive to soem types of rubber. If your car is runing the original line sthen you should be OK. But if the original lines have been replaced sepecially on the low pressure side (between pump and the tank) you could have problems - it's best to repalce the low pressure side with new lines. The high pressure side seem to be designed to take the mixtures of aromatics and rarely fail, most causes of failure are due to human intervention - bending the line sout of the way numerous time swhen working on the car. |
larso Guest
Posted: Tue Aug 27, 2002 7:44 pm Post subject: |
If the fuel lines look cracked it may be just the insulation, inside is a tube. You could make your own insulation to save on the costs (if the insulation is cracked fuel can't leak out, it just is prone to damaging the inside line more because no padding, and no heat preservation). The pump hose though is regular hose so if it has cracks replace right away.
Does toluene only corrode with oxygen, maybe the trick is to always keep fuel in the lines like keeping the tank full to prevent rust? |
Rick MacLaren Guest
Posted: Tue Aug 27, 2002 10:08 pm Post subject: |
I think it's the 'aromatic' combined with the oxygen that causes the problem. And John, I think you're note makes sense cause you're adding forces to old lines. I was messing with mine prior to replacing them - mostly moving that fuel distribution unit around. I figured it couldn't hurt to replace the lot of them. Lars, I think you're right about O2 being a catalyst for the cracking.
Dunno about fixing them. Thing is, if the insulation is cracked, it no longer insulates against heat, to spec. And cracks more. And on the 931 it's right above the exhaust. I tried fixing mine and just made a mess of it - used a good quality rubber tape. It held for a while, but, hey, I wasn't insured for fire. Both lines were only $60 a piece, or something like that. When I replaced them the gas smell went away.
Got an extinguisher in your car?
There's this story in the UCR PCA register about a guy in a 911 stopped in traffic in Toronto outside the Dupont St. Movenpick store. Fancy schmancy grocery place. He's sitting there, and smells smoke. Wife gets anxious. He looks behind him and his 911 RS America (I think) is aflame. So he gets out of the car, in traffic, goes into Movenpick. Grabs an extinguisher, takes it outside, and can't figure out how to remove the safety pin.
Ha!
So he's standing there, fighting with the extinguisher. I kind of imagine him red-faced, rolling on the ground with it, like in a Monty Python movie. And his baby is aflame. By the time he gets the pin out of the extinguisher the car is toast and the Metro fire department guys are chatting up his wife.
So why did the guy's 911 RS America blow up? He didn't spend the $50 bucks or whatever on a cooling fan belt, and his beautiful car ended up being a cooked like a weenie.
[ This Message was edited by: Rick MacLaren on 2002-08-27 22:23 ] |
