17" turbo twist w/o stock spacer
PostPosted: Thu May 28, 2009 11:44 am    Post subject: 17" turbo twist w/o stock spacer Reply with quote
Could I run my 17x9 turbo twists in the rear w/o the stock rear spacers and not have to roll the fenders? 255/40 in the rear...
Anyone do anything like this or would they rub on the inside then?
PostPosted: Thu May 28, 2009 4:37 pm    Post subject: Reply with quote
i'm sure you need spacers not to rub on the inside...those wheels have 50+ET while the stock ones have about half of that.
PostPosted: Fri May 29, 2009 2:52 am    Post subject: Reply with quote
ET55 on the rears..
Stock is ET52.3
emoore924
PostPosted: Fri May 29, 2009 2:54 am    Post subject: Reply with quote
IIRC, some *aftermarket* twists came with early offset that did not require spacers to run...
PostPosted: Fri May 29, 2009 3:11 am    Post subject: Reply with quote
ahh, well these are OE I think because they are 55mm offset.
i read raceboy ran some 10" wide rears w/o the spacers, but im not sure what that offset was.
FSMITH010
PostPosted: Fri May 29, 2009 6:58 am    Post subject: Reply with quote
I think they are 9" cup 1's. Now has 8.5" 18" twists in the rear.
http://www.924board.org/viewtopic.php?t=21373&postdays=0&postorder=asc&start=45
