Shurick
Posted: Tue Apr 14, 2009 9:02 pm Post subject: Belts/harness, latch-style. |
Looking at the Summit Racing store, found a lot of 5-point harnesses with a very affordable price. But I've never seen this style of latch before.
Is it secure enough in case of impact? _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Tue Apr 14, 2009 9:30 pm Post subject: |
i always wondered what happens to your balls in case you have a frontal impact wearing these things.  _________________ Supercharger and EFI kits
https://www.the924.com |
Shurick
Posted: Tue Apr 14, 2009 9:34 pm Post subject: |
The latch is placed a little higher then the balls.=) _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Tue Apr 14, 2009 9:43 pm Post subject: |
LOL!
Yes, they're safe - those are US military-spec buckles. Talking with one of the professors at the Wayne State crash lab (where they developed the HANS, among others), he pointed out that if you ever wear that buckle out, you should stop racing/crashing - your body will wear out first!
Camlocks, OTOH, will bend the pins and eventually fail after too many impacts - that's why they use the latch style in the crash lab, and why they also won't reweb camlocks more than once usually.
I've been using this style (latch-n-link) for 9 years now, since I started racing. I've crashed a number of times, most recently last November - never any issues.
That said, I'm going to be switching over to camlocks (from the same supplier, RJS Racing here in Michigan); the buckle on the latch is very large, relatively speaking, and as my wife is getting behind the wheel more than me now, the latch digs into her thighs quite a bit, and is very uncomfortable. A camlock buckle will take up less space and be more comfortable.
One more note - get a 6-point, not a 5-point (has 2 sub straps instead of one). They're safer and also easier to install, because they a) do a better job of restraining the pelvis, and b) can be bolted in at the same points as the lap belts, right at the stock 3-pt seatbelt attachment points either side of the seat.
Hope that helps... _________________ Vaughan Scott
Shurick
Posted: Tue Apr 14, 2009 10:31 pm Post subject: |
Thanks, Vaughan! That's what I really needed.
Here in Russia only OEM-style and camlock are common, so I have no experience with this style of latch.
Unfortunately, these latch-n-link harnesses are not homologated to club rally.=( _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Tue Apr 14, 2009 11:56 pm Post subject: |
Vaughan is right - the latch type is as safe as the cam-lock belts. However, they are more of a pain to buckle up. You must put all the harness parts together before you crank the buckle over. Cam Locks can be done one belt at a time.
I did have a latch type failure many years ago. I was running an open cockpit car and was required to also wear arm restraints to prevent roll bar amputation. Arm restraints are short straps that loop around your elbows and attach to the belt system preventing you from raising your arms over your helmet. Somehow, I managed to hook one of the restraints under the latching lever and popped it loose just as I was braking heavily for a turn. With almost 2 Gs of deceleration, my body raised out of the seat and I flailed around hanging onto the steering wheel. Luckily no damage except to my nomex underwear.
Chuck |
Posted: Wed Apr 15, 2009 12:52 am Post subject: |
They should carry FIA specifications, which is what most sanctioning bodies recognize and require. _________________ Stefan
Shurick
Posted: Wed Apr 15, 2009 1:05 am Post subject: |
| Fifty50Plus wrote: | | Luckily no damage except to my nomex underwear. |
I'd also damage my underwear in such situation.
| fiat22turbo wrote: | | They should carry FIA specifications, which is what most sanctioning bodies recognize and require. |
Those low-priced are only SFI 16.1 certified. _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Wed Apr 15, 2009 2:11 am Post subject: |
I'm not surprised that most of the cheaper ones in the US are only SFI certified, it's a US thing... naturally you'd have to get an FIA approved system.
Check out RacerWholesale.com - they often have FIA-approved camlocks cheaper than anywhere else, though no idea on shipping!  _________________ Vaughan Scott
Shurick
Posted: Wed Apr 15, 2009 9:04 pm Post subject: |
FIA approvement is not necessary for me, because my 931 is daily driver. It's also driven at rally-sprints (something like US auto-X) sometimes, but homologation is not obligatory there. And sometimes it's a safety car, but there is no need in FIA approvement for pacecar. _________________ WBR, Shurick
'86 924S -- R.I.P.
Nobbi
Posted: Fri Apr 17, 2009 6:53 pm Post subject: |
Shurick take a look at www.rennsportshop.com
You will find a harness,6-way,with fia approval for 98.-euros......  _________________ NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew..Plus : DEUTZ 4005 tractor Built 1967 |
Shurick
Posted: Fri Apr 17, 2009 9:24 pm Post subject: |
Wow!=) I like it!=) _________________ WBR, Shurick
'86 924S -- R.I.P.
