Martijnus
Posted: Sat Feb 28, 2009 3:34 am Post subject: My unusual turbo plans... |
I've bought two 931 heads from a forum member. Haven't got them yet, but that doesn't matter.
I'm now running:
- 2.0 NA engine
- Decked engine block (1mm), which raises CR to 10.2:1 (in my calculations)
- MSII EFI
- ITB's 40mm inner diameter
- stock exhaust system
What I'll add before I'll reveal my turbo plans:
- EDIS functioning on MSII
- LPI (liquid petroleum gas) injection additional to my gasoline injection, MS controlled.
The plan is to rebuild at least one of the two 931 heads and eventually put this head on my engine.
Mods I plan to do are:
- Replace valve seats to cope with the LPI injection
- Polish exhaust and combustion chamber for reduced heat absorption
- See if there's anything I can improve on the ports, but I don't want to do alot in case it has negative effect.
After that I have to choose a turbo.
My CR will be around 7.5:1 when I dump the 931 head on my current engine with euro NA pistons. Thats the same as the 931 S1, which put out 170hp with 0.8bar boost.
My goal is not power, but efficiency (ok and a little bit more torque/power), I don't want a thirsty daily driver and I think a turbo can improve MPG.
I'm thinking of a small turbo which spools very early and doesn't put out that much boost. max 200 hp on the rear wheels, but 170 should be more than enough.
The CR is one thing I'm worried about. if a 931 puts out 170 hp with 7.5:1 CR, no intercooler and 0.8 bar boost, I should obtain 170hp with 8.0:1 or 8.5:1 with say 0.5 bar boost, which means I can use a smaller turbo, which spools low rpm.
New pistons are an option...but $$$ is a problem. The dish in the turbo pistons can increase efficiency a lot iirc, that's why I don't understand the install of flattops (euro pistons would be in between....).
whats the CR of a 931 S2? I'm in doubt between 8:1 and 8.5:1 (cgt?)
There will be a intercooler too of course, and I'll have to fabricate both intake and exhaust manifolds to fit the turbo and the ITB's.
Haven't read 'maximum boost' yet, and I haven't got any measurements of the 931 heads but that's my plan...
Of course running on LPI with the turbo.
Any thoughts on this? Major downsides? (why put in a lot of money and effort when you can put out 200+ and still want +-170hp... for instance ) _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Sat Feb 28, 2009 3:40 am Post subject: |
the smaller turbo will yeild less lag, but will not be as efficent and will generate more heat.
as to a turbo helping MPG, this is a very false concept. You will get worse gas mileage with the turbo. _________________ 3 928s, |
Martijnus
Posted: Sat Feb 28, 2009 3:46 am Post subject: |
| Lizard wrote: | the smaller turbo will yeild less lag, but will not be as efficent and will generate more heat.
as to a turbo helping MPG, this is a very false concept. You will get worse gas mileage with the turbo. |
and why is that? gas mileage isn't that much of a problem though... as long as it isn't unbelievably bad... the lpg is thrice as cheap as gasoline over here...
anyway... can you tell me why boosting the engine won't be efficient? The only thing I can think of is that the turbo itself uses some power....
On the other hand.. the rpm's will be the same at a given speed, and so is the specific power needed to maintain that given speed... boosting wouldn't change a thing to that... probably only the throttle which would be less for that given speed. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Posted: Sat Feb 28, 2009 4:16 am Post subject: |
Well, that would be true to an extent.
A properly sized turbo for the amount of power you want to make, that can flow an efficient amount of CFM should generate only a negligable amount more heat, if any, over a large turbo working below its efficiency range.
If the turbo is too small, and you run increased boost, it will be a heat pump. _________________ [This Space For Rent] |
9xx
Joined: 18 Jun 2006 Posts: 627 Location: Jarvenpaa, Finland
Posted: Sat Feb 28, 2009 4:31 am Post subject: Re: My unusual turbo plans... |
| Martijnus wrote: | | Thats the same as the 931 S1, which put out 170hp with 0.8bar boost. |
Actually with 0.7bar of boost.
| Martijnus wrote: | | whats the CR of a 931 S2? I'm in doubt between 8:1 and 8.5:1 (cgt?) |
Series II
US = 8.0:1
Row = 8.5:1 _________________ Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944 |
Posted: Sat Feb 28, 2009 7:55 am Post subject: |
yup, we're talking ROW here..US ones are just detuned.
the S2 has 8.5 CR and runs 0.6 - 0.7 bar, my turbo puts out just 0.6 bar and it is in perfect condition..recently rebuilt.
What are you doing with the other head(the 931 cyl head )? i'd be interested in buying it...i want to do a bit of headwork myself but it would be much easyer if i had a spare head to work on while i can still drive my car. _________________ Supercharger and EFI kits
https://www.the924.com |
Martijnus
Posted: Sat Feb 28, 2009 10:49 am Post subject: |
| morghen wrote: | yup, we're talking ROW here..US ones are just detuned.
What are you doing with the other head(the 931 cyl head )? i'd be interested in buying it...i want to do a bit of headwork myself but it would be much easyer if i had a spare head to work on while i can still drive my car. |
Not sure what I'll do with the other head. Want to see them first and usability.
So I should probably get S2 pistons, but that'll give me over that 8.5:1 cr.
quick calc:
my CR would be 9.2:1 because the block is skimmed.
with the apparently US pistons (8.0:1) i'd have 8.6:1.
Purely based on intuition I'd say that that 8.6:1 will be the most ideal.
If a S2 can run 177 (right?) hp with 0.7/0.8 boost (non intercooled?) I'd be able to reach that hp with 8.6:1 and an intercooler or so and less boost.
So I have the choice:
Euro NA pistons: 7.6:1
Euro931 S1 pistons: 8:1
Euro931 S2 pistons: 9.2:1
US 931 S2 pistons: 8.6:1
Wonder what 8.6:1 theoretically does in HP on 0.5 bar boost. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Posted: Sat Feb 28, 2009 1:19 pm Post subject: |
It wont be significantly less MPG, but a couple.
The reason being is that the turbo will always be moving alittle more air in there as normal. more air, more fuel. _________________ 3 928s, |
Posted: Sat Feb 28, 2009 3:36 pm Post subject: |
No intention of getting bogged down here with your hypothetical CR calcs, only will say though that if you dont accurately know the actual volumes you may as well be pulling rabbits out of a hat. Hopefully you measured your piston/cylinder volume when you built your motor and decked the block.
931 chamber volume is supposed to be 21.5cc but any previous valve work or milling over the last 30 or so years will alter that. So suggest you CC them when you have them.
Gasket thickness will play a large part too. No idea where the 1.25mm (0.51") figure came from that is suggested in other threads since all stock ones I`ve measured are 1.6 - 1.7mm. Slip some feeler gauges under your head to verify.
Heres some better online calculators:
http://www.csgnetwork.com/compcalc.html
http://www.not2fast.com/turbo/compression/compression.shtml
With 9.3:1 Euro pistons at +1.0 (87.5) and a deck height of 4.1mm (- 0.5mm from the last time?) the volume measures 44cc. Irrelevant to your build but may just give you something to go on if you have no other data.
Will be amazed if you manage to increase MPG with a turbo.  |
Raceboy
Posted: Sat Feb 28, 2009 10:17 pm Post subject: |
No turbo will improve MPG.
And actually the smaller turbo you use, the worse MPG you get. Why? Because smaller turbo has more restriction to the exaust and it spins earlier resulting boost very quickly. With bigger turbine you'll get your target hp (say 200?) and turbo is basically used just for the peak hp, not for ultimate torque. MPG will be BETTER because on normal cruise situation turbine creates less backpressure and is less burden to the engine.
Your MPG will be worse compared to NA with whatever turbo you use, only it will be less worse with bigger turbine (as for compressor, it doesn't matter much on cruise). _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Martijnus
Posted: Sun Mar 01, 2009 2:00 am Post subject: |
| Raceboy wrote: | No turbo will improve MPG.
Your MPG will be worse compared to NA with whatever turbo you use, only it will be less worse with bigger turbine (as for compressor, it doesn't matter much on cruise). |
So if I understand you correctly, I just should look at how much HP I'd like to have with some theoretical CR (between 7.5 and 9.3 should work anyway) and search for the turbo which is the best one for that application.
Only thing not used in that equasion is the boost.
I completely understand that a small turbo which could put out say max. 1 bar ran on 0.5 bar creates backpressure, which in turn has negative influence on my filling degree and EGT.
edit: some quick calcs (rough) in a datasheet learned me that with a impreza WRX turbocharger (TD04L) I'd have 177 hp with 0.5 bar boost (which is the limit iirc for a WRX).
That engine has a CR of 8.5:1 approx. so if I'm in those ranges I should have a right combo for my usage. That turbocharger isn't really really small... _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Posted: Sun Mar 01, 2009 4:35 am Post subject: |
Martijnus,
I am afraid that you arent really knowing what you are wanting at this point in time.
Get and read max boost by corcky bell it will be a great starting point.
However to pick what size of turbo you want.
You need a HP goal,
you then need to determine how many lbs of air/hr it will take for the engine used to achieve that.
Then you need to read the compressor maps and chart out roughly where that would put you on the compressor map. Once that is done you have your turbo. _________________ 3 928s, |
ic932
Posted: Sun Mar 01, 2009 5:11 am Post subject: |
I used to get approx 20mpg out of a well tuned but stock 932 which was my "partial" daily driver (if that makes sense). My other daily driver was a BMW325i (touring). Both had similar power outputs (170-80BHP.) The BMW had the better fuel economy which is no surprise.
I'm suprised that with modern EFI/turbo-charging that it isn't possible to better the 931's MPG....Is this the consensus view here? |
Martijnus
Posted: Sun Mar 01, 2009 11:08 am Post subject: |
| Lizard wrote: | Martijnus,
That's right, that's why I posted these plans, to get some feedback
| Quote: |
Already have it on my pc... just have to read it...
but english...it's so hard. (oh wait, it's not).
| Quote: |
You need a HP goal,
Then you need to read the compressor maps and chart out roughly where that would put you on the compressor map. Once that is done you have your turbo. |
Well the goal is between 150-190 hp. Since you can achieve 150 hp with bike carbs, I wouldn't be surprised if my car puts out a little bit more at the moment than the 125 stock (on the other hand, let's not overestimate it)
I sure don't want to go over 200rwhp because I'm afraid of the rod bolts and clutch.
| Quote: | I used to get approx 20mpg out of a well tuned but stock 932 which was my "partial" daily driver (if that makes sense). My other daily driver was a BMW325i (touring). Both had similar power outputs (170-80BHP.) The BMW had the better fuel economy which is no surprise.
I think this should be possible. I never liked the Kjet (when it's 20yrs old) and the ignition probably holds back a bit too. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Raceboy
Posted: Sun Mar 01, 2009 5:49 pm Post subject: |
I didn't say EFI isn't improvement over K-Jet, I said that when adding turbo to existing EFI engine, you will get worse MPG.
And obviously if you add turbo to K-Jet, same story.
After my efi and turbocharger install to white 924, MPG is roughly the same as it was with NA form and old K-Jet, maybe a little bit worse (better on the highway, around 7-8l/100 km/h and worse in the city due to lots of acceleration). _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
