ourkid
Joined: 04 Aug 2008 Posts: 84 Location: Ellesmere Port,Cheshire UK
Posted: Fri Nov 28, 2008 5:08 pm Post subject: Update....low cranking voltage? |
From my earlier post,24hrs after fitting a new battery,my engine cranks over great but i'm only seeing 8v at gauge whilst cranking??? (engine won't fire)
I see 13.5v when running,so why is my voltage being dragged down so much?,could this be a starter problem?
Ade. _________________ 1983 924 N/A |
ourkid
Posted: Fri Nov 28, 2008 5:14 pm Post subject: |
Just a thought,could someone tell me the spec (cold cranking amps)of the correct battery? (I may have been sold a dud  _________________ 1983 924 N/A |
Rich H
Posted: Fri Nov 28, 2008 8:03 pm Post subject: |
Could also indicate a tired solenoid or starter. I can't help as I'm on EFI and wasted spark  _________________ 1994 Lotus Esprit S4 - Work in progress...
michi924
Joined: 22 May 2007 Posts: 163 Location: Pontevedra, Spain
Posted: Fri Nov 28, 2008 9:35 pm Post subject: |
Hello. Did you check the voltage in the 15 pin at the coil?
It's normal a drop in voltage while cranking due the great amount of amps. that the starter needs.
First of all check the voltage in the coil (15) while cranking. You should get 5-8volts whit the ignition on, and 10-12v while cranking. _________________ Porsche 924 NA Euro. |
ourkid
Posted: Sun Nov 30, 2008 6:54 am Post subject: |
Fresh battery - showing 10v,dropping to 8 whilst cranking.I then noticed that the CD player facia was lighting up when cranking
So, i pulled the removeable facia off and the car fired up straight away.
At least i know the battery and ignition circuit are ok,but the wiring to the CD is obviously suspect (christmas project)
Thanks for the input!
