924turbo_sout_africa
Posted: Fri Oct 24, 2008 3:08 am Post subject: head noise |
ok boys wel i had my head redone with a 280s type camm it is what they use in the 924 challenge this side. they side it is the same as 288 degree cam
well i had it in for about a month now and there seems to some funny noise from the head sounded like bearings when you rev it and let go there is a grr sound ....but after some checking i found that 2 of the srews for the shim buckets where gone so i want to find out it looks like normal grup screws can i just take one out and replace them with the same size or is it a special kind of screw....
o yes the 2 screws i think was never put in by mistake so they are not in the motor very lucky for that as i did a strip down of the motor _________________ Porsche ...where dreams are a reality
'79 924 turbo canada spec
'98 Formula Vee (M3 eater)
Time in the 931 is a dream come true !! |
emoore924
Posted: Sat Oct 25, 2008 3:24 am Post subject: |
Did your rebuilder use lash caps instead of adjustor screws? This might be why there were no screws, but if 2 were not there it should be all not there, not some there and some not there.
In any case, the screws are NOT all the same. There are 4 sizes I think, indicated by little hash marks on the end of the screw -- none, 1, 2, or 3 (maybe 4) indicating the thickness of the screw. Check the tech section here at 924.org.
If lash caps were used, typically, they are like shims and you need to pick the right thickness for the valve lash you want. Mix-n-match.
Go back to your rebuilder and find out what's going on... |
Posted: Fri Nov 07, 2008 3:27 am Post subject: |
hey sorry only getting back now work is crazy...
wel it is not sims in the head it uses screw's but spoke to a dude who works on 924 this side he said i must bring it in and he will fix it for me ...and then get everything setup on the dyno
but thanks for the help _________________ Porsche ...where dreams are a reality
Posted: Wed Nov 26, 2008 3:35 am Post subject: |
hey all
been busy finishing my season in racing havent had the time to work on 24 but now i want to sort this ...steve (bass gt ) is here so i just want to find out is it possible to take the screws out and then put in simms to take up the gap ? or do i need to change the valve caps to do that ? _________________ Porsche ...where dreams are a reality
