Odd lighting problem
Lightning22
PostPosted: Thu Nov 13, 2008 3:08 am    Post subject: Odd lighting problem Reply with quote
I'm hoping for some suggestions from the boards learned members here...
My other halves 1986 924 (UK spec) dropped a little surprise this morning when she set off for work.
When she switched on the lights the lights popped up, sidelights and dash etc lit up but no dipped beam. The tail lights work fine, the main beam flash works but doesn't lock 'on'.
The earths at the headlamp end are patent, there are no blown fuses (that I can find).
I've rigged a bypass circuit so the headlamps light when the sidelights power up, the bulbs are working fine. When bypassed the main beam still won't lock on.
HELP!
Rich
Slam
PostPosted: Thu Nov 13, 2008 3:52 am    Post subject: Reply with quote
Top of my head? Fuses 1,2,3,4 on main fuse block. Indicator/hi-lo beam switch-stalk. Is the car an S or regular 924? The former's hi-lo beam switching is on the steering column. Not sure about late latter but my wife's 77 has relays for the hi-lo.
HTH
I'm sure someone who knows much more than me will chime in.
'84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably
Lightning22
PostPosted: Thu Nov 13, 2008 6:15 am    Post subject: Reply with quote
Hi,
Thanks for the response, it's a straight 2.0 924 the fuses all appear ok. The hi-lo switch appears to be doing it's job in terms of making the high beam flash.
Rich
Slam
PostPosted: Thu Nov 13, 2008 7:05 am    Post subject: Reply with quote
How about the connector to the column switch? IIRC, the Euro 924 does have a relay Haynes calls a changeover relay. Not sure exactly what its role is, though.
'80 924 - gone
'78 924 - gone
Ozzie
PostPosted: Thu Nov 13, 2008 7:37 am    Post subject: Reply with quote
No relay on mine- just uses the switch.
I would say the switch is fubar.
Its AUTO and its BLACK
Montego Black on black/red
Lightning22
PostPosted: Thu Nov 13, 2008 7:57 am    Post subject: Reply with quote
If you mean the main light switch then that's where I'm going too, I've had it out of the dash and it's quite a complex beast. I guess the only way to know for sure is to fit another switch.
All I've got to do now is find one.......
Slam
PostPosted: Thu Nov 13, 2008 9:58 am    Post subject: Reply with quote
This link may help if the car's similar to an early 944 (my Euro 924 is almost exactly the same).
http://www.pelicanparts.com/944/electrical/944_84_2_1.jpg
Hmmm...that may be just an annoying teaser. The wiring diagrams are on the PelicanParts website. Have a look there.
'80 924 - gone
'78 924 - gone
Slam
PostPosted: Thu Nov 13, 2008 10:00 am    Post subject: Reply with quote
http://www.pelicanparts.com/944/electrical/944_electrical_diagrams.htm
That's better.
'80 924 - gone
'78 924 - gone
Ozzie
PostPosted: Thu Nov 13, 2008 4:05 pm    Post subject: Reply with quote
I meant the changeover switch on the column but I'd chase the circuit from the dash switch.
3d914
PostPosted: Sun Nov 16, 2008 8:29 am    Post subject: Reply with quote
Rich,
I'm chasing the very same problem on my 87-924S (US). There is no relay on this year. I'm not getting volts to the fuses. I pulled the switch and checked it, and it checked out OK. I also replaced my column switch - still the same thing.
Anyone solved this one before?
TIA,
Gerard
74-914 2.0L Ravenna Green
87-924S 2.5L Alpine White
Lightning22
PostPosted: Sun Nov 16, 2008 7:08 pm    Post subject: Reply with quote
I'm still stuck, awaiting a replacement switch at the moment.
Jaf
PostPosted: Tue Nov 18, 2008 3:21 am    Post subject: Reply with quote
The later cars don't use a relay? How strange. On my car you pull the lever to put the main beam on and then pull it again in the same direction to turn the main beam off again. There's no way of making the main beam flash as such, just on/off. Even when the relay's broken (as it is again now) holding the lever makes the main beam come on, it just won't stay on.
1978 924na
Lightning22
PostPosted: Tue Nov 18, 2008 7:37 am    Post subject: Reply with quote
Mine has no lighting relay for the dipped lights, but there is one for the main beam.
Lightning22
PostPosted: Wed Nov 19, 2008 11:05 pm    Post subject: UPDATE! Reply with quote
I've just replaced the main light switch (the one with the instrument dimmer combined into it) and I now have lights again!
Thanks for all the suggestions and help.
Rich
