Using "hot start" fix to bypass my thermo switch
ourkid
PostPosted: Wed Oct 29, 2008 10:35 pm    Post subject: Using "hot start" fix to bypass my thermo switch Reply with quote
A slight twist on the by now "done to death" hot start issue.
I figured during the summer that my cold start valve was operating for the maximum duration during every start,regardless of engine temp,or surrounding temp.This caused flooding and complete non-start until i un-plugged the valve(then giving instant start-up).
Anyway,i've been using the car for a few months with it disconnected.Yesterday it went to 2 degrees and i had to plug it back in.
I can see how much of a pain it is to replace the thermo switch so i was thinking of using the hot start fix to rig up a switch for manual control.
HOWEVER..... if i splice into the earth (as per instructions on this forum),i will still have the normal operation in place and will still get problems when hot.So what if i cut the earth,instead of "piggy backing" it and put a switch in the earth line.Then i have total control all the time?.Will this affect anything else.
I will replace the thermo switch eventually (after cleaning my WUR,fitting a Carerra kit,new mats etc...etc....list goes on...)
1983 924 N/A
Rich H
PostPosted: Wed Oct 29, 2008 11:28 pm    Post subject: Reply with quote
TTS is easy to replace, it just takes time.
Dizzy out
Unplug TTS and temp sender
Drain coolant (Take the opportunity to flush and replace)
Disconnect 2 pipes to TTS casting
Undo the 2 bolts that hold the TTS casting & remove
Remove TTS from casting on the bench
Replace.
Doesn't take that long
Failing that just wire the CSV into a push button and ignore the TTS altogether.
PostPosted: Thu Oct 30, 2008 2:49 am    Post subject: Reply with quote
+1 to Rich, be patient and fix it right.
ourkid
PostPosted: Thu Oct 30, 2008 3:39 am    Post subject: Reply with quote
Thanks for the guide Rich,I'll still fit a switch for now...just been out in the garage and it's too damn cold!
Ade.
1983 924 N/A
Brockoli
PostPosted: Thu Oct 30, 2008 7:00 am    Post subject: Reply with quote
i changed my TTS from under the car. I didnt take the dizzy out. In fact i didnt even jack the car up, this was before I lowered it. Its hard to get to but its not that bad of a job.
I didnt realize that it was a plug for the coolant tho, I was pretty new to the car. The only problem I had was getting out from under the car before the coolant gave me a bath, that was very exciting. I think i used a normal wrench too, nothing tricky.
Rich H
PostPosted: Thu Oct 30, 2008 7:22 am    Post subject: Reply with quote
One of mine was properly stuck in, it undid ok, the threads came out, but the end was stuck fast!
