4x6 (6x4) Front Door Speaker choice - fitment question
Sy924
PostPosted: Sun Oct 19, 2008 4:19 am    Post subject: 4x6 (6x4) Front Door Speaker choice - fitment question Reply with quote
Hi,
Anybody have any success fitting speakers of this type into the doors of their 924?:
http://www.alphacaraudio.co.uk/ViewProdDetails.asp?prod_code=432&Prod_name=JBL+Power+P%2D6452+&CAT_CODE=31&SUBCAT_CODE=74
I'd like to know if they're likely to go straight in or if I'm going to have to butcher them to make them fit.
Cheers,
Sy
cgalyon
PostPosted: Sun Oct 19, 2008 6:57 am    Post subject: Reply with quote
What year is it? I was able to fit slightly smaller speakers (3x5? I'll have to check) into my front door panels with no problems, but my car is an '88 924S.
1988 924S Navy Blue - Phone Dials
billson
PostPosted: Sun Oct 19, 2008 8:38 am    Post subject: Reply with quote
The screw holes in the door should be for a 6x4 speaker.
I managed to get some 6x4 speakers to fit. But due to the mounting depth I had to make a spacer to pull the speaker out a bit more and use longer screws. A bit of wood painted black with a hole cut out for the speaker cone did the trick nicely
1983 924 NA
Guards Red
Carrera GT bodykit
Larger VW throttle body
cgalyon
PostPosted: Sun Oct 19, 2008 9:04 am    Post subject: Reply with quote
Ah yes, that's right. The speakers I installed were full sized, but they were shallow. So if you can acquire some shallow speakers or mock up something like billson described.
PostPosted: Sun Oct 19, 2008 9:43 am    Post subject: Reply with quote
More info than you need HERE
Sy924
PostPosted: Tue Oct 21, 2008 6:17 am    Post subject: Reply with quote
Thanks for the replies guys - yep my car is a 1988 UK 924S.
Yeah, they're 4x6 (or 6x4 whatever you want to call it), so I'm sure they'll fit the hole mounting points ok, but it's the rear mounting depth (i.e. behind the panel) I'm not sure about.
Cheers,
Sy
