Fuchs wheels
mhart
PostPosted: Mon Jul 14, 2008 1:49 am    Post subject: Fuchs wheels Reply with quote
I have a lead on a set of Fuchs wheels that are for sale. They are part number 911361020, and the seller says that they are 15x6" and late offset. This means that they should fit my 924S OK right?
I really like the look of Fuchs and was pretty pleasantly surprised at the possibility that I might be able to fit these to the car. Thoughts/advice?
'87 924 S - No sunroof and a few modifications
PostPosted: Mon Jul 14, 2008 11:05 pm    Post subject: Reply with quote
Care is called for, as I believe there are at least two different styles of hubs on the 924S. I don't know the particulars, but I do know that I acquired a set of 15x7 cookie cutters with "late offsets" that are known to work on 944s but would not mount correctly on my 87 924S. I don't know the definitive authority on this topic, but I would advise a bit more due diligence before plunking down your cash.
PostPosted: Tue Jul 15, 2008 9:16 am    Post subject: Reply with quote
I had a set of eaqrly 16x6s that had the right off-set though,I was able to switch the rears out with a set 16x7s.
J1NX3D
PostPosted: Tue Jul 15, 2008 11:48 am    Post subject: Reply with quote
i may be wrong, but didn't the 924S have early 944 suspension, hubs etc so offset as well?
the offset changed from 85.5 onwards for 944's when they got aluminium A Arms, etc.
'86 944
mhart
PostPosted: Tue Jul 15, 2008 4:03 pm    Post subject: Reply with quote
924S's do have more or less the early suspension (ie 924S suspension parts are interchangeable with early 944/86 951 suspension parts) but to fit the wheels under the narrow fenders, Porsche fitted late offset wheels
Zermatt924SUK
PostPosted: Tue Jul 15, 2008 7:09 pm    Post subject: Reply with quote
Is it 52.3 on 1988 924S?
1988 924S Zermatt Silver
PostPosted: Tue Jul 15, 2008 10:44 pm    Post subject: Reply with quote
If I'm not mistaken, there are at least two different hub styles on the 924S. Information is sketchy, but I do recall reading about it here somewhere, and in fact, when I tried fitting my 7Jx15 H2 cookie cutters, it wasn't only the offset that was wrong, the hub was not the same size and would not fit into the opening on the wheel.
PostPosted: Wed Jul 16, 2008 12:49 am    Post subject: Reply with quote
Front Hub for 924S:
477 405 065 B (same as vented disc 924, and early 944 NA)
Rear hub for 924S:
951 331 067 00 (no year/option split indicated in PET)
bcblase
PostPosted: Sat Aug 30, 2008 10:57 am    Post subject: Reply with quote
I can tell you that late offset 16x7 wheels DO NOT fit on the 924S - they stick out of the wheel wells quite a bit. You need to stick with the 52 mm (early offsets) unless you roll the fenders, or install flares.
BC
1987 Porsche 924S - track toy
1986 Mercedes 190E 2.3-16v - autocross
2007 F-150 5.4L Lariat Supercrew - tow beast
1994 Volvo 850 Race Wagon - 24 Hours of Lemons Car
2001 BMW 325xi - daily driver
mhart
PostPosted: Sat Aug 30, 2008 2:47 pm    Post subject: Reply with quote
bcblase, I think you might have early and late offsets mixed up...
early offsets were around 23.xx mm offsets and you're right, those won't fit
late offsets were around 52mm, and I can say that those will definitely fit - I have a set of late offset phone dials on the car now.
My thought was though that an early offset 6" wide wheel would stick out about as much (w/in a couple mm) from the hub, so I might be able to fit fuchs on the car (which I think would really tie the look together nicely, and its not like my car is making enough hp at this point to really overwhelm the skinnier tires)
PostPosted: Sun Aug 31, 2008 12:14 am    Post subject: Reply with quote
My Fuchs's are that same part number (911.361.020 FCO), but are 16x6 - http://www.924board.org/viewtopic.php?t=21373&start=11
They're offset=36mm, which is 16mm less than my cars' stock offset of 52.3mm. This has the Fuchs 5-spokers sitting 16mm further outboard than stock and they rubbed the fenders on sharp turns and bumps. The suspension changes mentioned in that link alleviated those problems (stiffer springs + thicker front stabilizer bar + added rear bar to lessen body roll). Also, there's a quirk common to 924 bodies - the rear-left fender is about 10mm closer to the tire, so I also have to use a thinner spacer* at rear-left when the 5-spokes are in use.
*- (5-lug 931s came with factory installed spacers in the rear)
PostPosted: Sun Aug 31, 2008 3:08 am    Post subject: Reply with quote
Thats interesting. Is that what you measured or is there more info about this?
Recall there was some discrepancy when doing body work. Thought it may have been the RH side that was closer but that was the side I was working on and to keep the same "lines" just accepted the variation. Suspected I may have had a bent trailing arm but alignment was OK.
Was it designed like that? or a F up or just the manufacturing tolerance?
PostPosted: Sun Aug 31, 2008 5:00 am    Post subject: Reply with quote
Yeah, I don't recall where I first read it, but apparently it's a manufacturing "feature" common to all 924s. When I found mine still rubbing at the rear-left after doing the suspension mods, I assumed it was due to some less than perfect accident repair (that left quarter panel was replaced due to an accident before I owned the car)
Several years later I read that they all have less room at the left side..
PostPosted: Thu Sep 04, 2008 10:24 am    Post subject: Reply with quote
Hmmm thats interesting enough.
