Weber carbs question
PostPosted: Thu Apr 17, 2008 9:23 pm    Post subject: Weber carbs question Reply with quote
Working on the weber 40 dcoe conversions and I don’t know what to do with the engine breather line that connects to the air box.
What you guys did with it?
Do you know if that line needs any sort of vacuum on it?
Chrenan
PostPosted: Fri Apr 18, 2008 12:05 am    Post subject: Reply with quote
Even with my CIS I run that to atmosphere. I'd rather lose the vacuum on the crankcase than have all the crap recirculated through my intake. I fully understand the benefits of keeping a vacuum on the crankcase, but I could care less. I don't have any running issues, however, I have a very fresh engine rebuilt a couple of years ago with low kms. On a tired engine getting rid of the crankcase vacuum might cause increased blow by?
PostPosted: Fri Apr 18, 2008 2:02 am    Post subject: Reply with quote
Yeah, no PCV can also cause rear main seal leaks - ask Porschev.
924-76
PostPosted: Fri Apr 18, 2008 3:01 am    Post subject: Reply with quote
So, to be safe I should keep that line on vacuum?
Any recommend setup?
Any picture from any one who are running the weber would be appreciated.
PostPosted: Fri Apr 18, 2008 3:34 am    Post subject: Reply with quote
When I had Webers on my 914, I bought nylon elbow fittings and drilled holes to take them in both air cleaner lids. I then teed it together and to the CCV.
924-76
PostPosted: Fri Apr 18, 2008 3:47 am    Post subject: Reply with quote
What do you thing if I put a small filter (like a carbs full filter type) on the line and connected the line with the brake booster vacuum line.
PostPosted: Fri Apr 18, 2008 3:54 am    Post subject: Reply with quote
You don't want to put manifold vacuum on the crankcase. Use the air cleaners or nothing as Chrenan did (at the risk of oiling your clutch).
If you use nothing, I seem to recall somebody (K&N maybe) selling a mini-air filter for your breather hose that looks pretty cool (but is entirely non-functional).
924-76
PostPosted: Fri Apr 18, 2008 4:01 am    Post subject: Reply with quote
The line is presently attached to the air box behind the air filter.
The way that air box is designed, is that would be the same vacuum then at the manifold?
PostPosted: Fri May 02, 2008 7:40 am    Post subject: Reply with quote
Nope, the vacuum behind the throttle plate is higher than behind the air filter.
If you want to get fancy, you can add a vacuum barb to the exhaust and pull vacuum that way. There are kits for this since you have to get the barb in the exhaust at the right angle and depth to work properly. Drag racer love the fact that it increases the vacuum in the crank case, helping the rings seal, among other things.
AppleBit
PostPosted: Fri May 02, 2008 11:16 am    Post subject: Reply with quote
i have docs on my website
