My First DE Event
bcblase
PostPosted: Tue Apr 08, 2008 10:50 am    Post subject: My First DE Event Reply with quote
Not a big deal by most of you guys' standards, but I participated in my first DE event at Summit Point, WV today. We ran the main circuit in groups of about 10-12 cars. We got five 20-minute sessions through the day - I was in the "green" group of novices. My instructor was pretty cool - he thought I was good enough to solo on the last run of the day!
I kept up with most of the cars in the group and ended up ahead of the pack on my last couple of runs. One guy in a 944 NA tried to stay with me, but couldn't keep up, and faded into the turns behind me...
Cool stuff - can't wait to try it again!
Ready to pass the 'Benz...
Cya!
Out in front...
all alone...
1987 Porsche 924S - track toy
1986 Mercedes 190E 2.3-16v - autocross
2007 F-150 5.4L Lariat Supercrew - tow beast
1994 Volvo 850 Race Wagon - 24 Hours of Lemons Car
2001 BMW 325xi - daily driver
Neil924
PostPosted: Tue Apr 08, 2008 11:36 am    Post subject: Reply with quote
That's great. Learning how to drive quickly is a life long test. Never push past the limits of the car, your body or your mind and you'll be safe and have a blast. The only question is "Where are those limits?"
bass gt
PostPosted: Tue Apr 08, 2008 11:58 am    Post subject: Reply with quote
usually lurking near the Armco
Front Wheel Drive is the Devil's work.
Neil924
PostPosted: Tue Apr 08, 2008 12:00 pm    Post subject: Reply with quote
Nice!
We have a development near us, a few high rise condos going up, they're called "The Armco".
Every time I drive I expect it to fall down or lean quite far to one side. lol
bcblase
PostPosted: Tue Apr 08, 2008 12:57 pm    Post subject: Reply with quote
There's one thing that keeps nagging at me...
The car handles unbelievably - I can't believe the speed at which I was taking some of the turns, and the car was sticking like I had glue in the tires.
So, if it's smoke that keeps the engine running, what keeps the car on the track? It must be the glue, right?
BC
P.S. Geeez...I'm gonna have trouble sleeping over this tonight.
PostPosted: Tue Apr 08, 2008 11:03 pm    Post subject: Reply with quote
Close - it's the noise. The noise in the tires.
Good job! Welcome to the Dark Side!
JSilverman
PostPosted: Thu Apr 10, 2008 9:45 am    Post subject: Reply with quote
Actually its the smoke being stored in the tires that keeps them planted on the road. Once you start letting the smoke out they no longer stick.
PostPosted: Thu Apr 10, 2008 10:33 am    Post subject: Reply with quote
As you get more experience you'll find the limit and be able to stay there. If fact to be really fast, experts enter a corner 2 or 3 mph faster than the limit, setup a controlled slide to scrub off the 2 or 3 mph and finish the corner at the limit.
PostPosted: Thu Apr 10, 2008 11:50 pm    Post subject: Reply with quote
That sounds like fast in, slow out, Paul...
JSilverman
PostPosted: Fri Apr 11, 2008 2:12 am    Post subject: Reply with quote
A couple local guys rented Summit Point and Flew Chris Cervelli out for private instruction. That is exaclty how he said to drive these cars because they dont accelerate very fast so you need to be fast entering the corner or something to that effect. If you search over on rennlist for posts by TDinDC he has all sorts of data acquisition showing that its faster etc.
PostPosted: Fri Apr 11, 2008 2:35 am    Post subject: Reply with quote
That's how Shaggy seems to get around fastest, with a bit of trail braking to rotate the car and avoid the understeer I cleverly designed into the chassis.
PostPosted: Fri Apr 11, 2008 8:11 am    Post subject: Reply with quote
Wanna race? (Only kidding wheel to wheel racing is on my "used to do" list)
This method results in the same exit speed.
PostPosted: Fri Apr 11, 2008 8:20 am    Post subject: Reply with quote
Get rid of the larger tires in the rear so you can oversteer at will!
PostPosted: Fri Apr 11, 2008 9:41 am    Post subject: Reply with quote
Anytime, tough guy...
As I said: "That sounds like fast in, slow out."
Or, perhaps a little more clearly:
As for shaggy - doesn't sound like there's anything wrong with the rear end, leave it alone! Rather, add a little more grip on the front!
Of course, the more astute out there will realize that this is exactly what trail-braking does...
PostPosted: Fri Apr 11, 2008 9:54 am    Post subject: Reply with quote
An aging man sighs as he remembers his youth....
In regards to shaggy, four tires of the same size, IMO are easier to setup for neutral handling.
