Raceboy
Posted: Tue Oct 30, 2007 4:35 am Post subject: |
So, finally got to the dyno today and results were pleasing to say at least 206 rwhp/265 rwNm. Guessing 18% (very optimistical about fiunal hp numbers ) gives app. 245 hp/315 Nm at the flywheel.
That was with 0.97 bars of boost.
Here's the graph. You can see that turbine is pretty big for that setup but it has good torque down low due to being 9.3:1 CR.
 _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Min
Posted: Tue Oct 30, 2007 6:06 am Post subject: |
Wow, what are the spec's on the turbo you used? You didn't make any internal changes to reach those numbers?
Raceboy
Posted: Tue Oct 30, 2007 6:16 am Post subject: |
Absolutely stock euro 924 engine.
I don't know the specs of the turbo, but it's from Hyundai Terracan 2.9 diesel engine. It says IHI KHF5-1A on the label. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Min
Posted: Tue Oct 30, 2007 6:29 am Post subject: |
google's not showing much as far as information on that turbo. What are your next upgrade plans?
Posted: Tue Oct 30, 2007 7:18 am Post subject: |
congrats ! great results !
So what we know until now is that the 924 NA engine will take almost 1 bar of pressure if managed right..and aparently is not of so poor design afterall if boosted corectly. The gearbox and tranny will take over 245HP but the clutch will slip.
Now..this shoud shut up some mouths and get some minds working. Everybody on to their projects now ! go go go !  _________________ Supercharger and EFI kits
https://www.the924.com |
endwrench
Posted: Tue Oct 30, 2007 7:36 am Post subject: |
WOW! Very nice numbers! Did you do some tuning on the dyno? How 'bout the clutch? At what RPM does your boost peak?
Todd _________________ '79 924NA. Rebuilt 9.5:1, MSDS header, Mega Squirt Injection, MJLJ-EDIS Ignition, 1.6L Whipple Charger and Intercooler, 10lbs Boost, 944 Trans, Custom HD Clutch.
"simsport" said....superchargers are better than turbos its official!.... |
Raceboy
Posted: Tue Oct 30, 2007 2:55 pm Post subject: |
I didn't tune it on the dyno, just measured the result.
Boost peak is on 4000rpm and holding it until the end.
Morghen, that head is poor design because normal engines would make at least 300 hp at nearly 1 bar of boost.
Clutch was so-so, if I'd tune the engine to more power, it would slip. On gearchanges it doesn't hook up sharp. And I tried for last pull to advance timing by 2 degrees, it made 13 hp more, but unfortunately I don't have graph for that. And I wouldn't dare to tune it without stethoscope. At this graph, I was running 26 degrees of total advance (base timing verified and spot on). _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Posted: Wed Oct 31, 2007 3:14 am Post subject: |
yea....modern 16V engines would. however 245HP and 944T-S performance. from an engine that everybody calls bad and slow is more than a lot. again. congrats ! you tha man !  _________________ Supercharger and EFI kits
Posted: Wed Nov 14, 2007 9:49 am Post subject: |
| Quote: |
Good news !..now does anyone have some nice old articles to prove this just so that the ana% car inspectors here in aus that approve upgrades can see that i wont need any other upgrades (such as from drums to disks, torque tube, gearbox etc etc) other than a stronger clutch.?? _________________ 1979 NA
my Porsches Arse!!! |
804kid
Posted: Thu Mar 20, 2008 9:53 am Post subject: |
we need to get some updates on this, im so lost on why you are advancing the timing and why you need a stethascope? anyway i have 1979 924 with like 90xxx and my plan is to weld together some piping like you did and basically take the turbo system out of my talon tsi and swap it into my porsche . the turbo is mitsu 14b, if i just bolt all this up am i going to totally destroy my engine, i was planing on running like 8-9 psi, and then driving it... but everyones got me scared because i keep seeing so many idea that i have no clue about.. can i just bolt the turbo up and go? whats the worst case senario?
thanksss |
tuurbo
Joined: 08 Aug 2007 Posts: 1446 Location: East Windsor, New Jersey
Posted: Thu Mar 20, 2008 10:00 am Post subject: |
Worse case scenario would be 'kaboom' I should think. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
804kid
Posted: Thu Mar 20, 2008 11:34 am Post subject: |
| lol ok ok, how should i go about this, any steps i seem to forget, im going to hook up all plumbing, set the turbo to 8 psi, turn the car on, let it run for a bit, and then give it hell? anything i missed? |
Posted: Thu Mar 20, 2008 12:19 pm Post subject: |
| ignorantporscheowner wrote: | | im going to hook up all plumbing, set the turbo to 8 psi, turn the car on, let it run for a bit, and then give it hell? |
Post back when you have the plumbing hooked up. Don't worry, we'll be here. _________________ Toofah King Bad
804kid
Posted: Thu Mar 20, 2008 12:35 pm Post subject: |
well i got all the parts needed, im pretty sure i can get it all hooked up by saturday, then id just be scared to start it i guess  |
71vdubturbo
Joined: 28 Nov 2006 Posts: 75 Location: Rolla, Missouri
Posted: Thu Mar 20, 2008 1:13 pm Post subject: |
| ignorantporscheowner wrote: | we need to get some updates on this, im so lost on why you are advancing the timing and why you need a stethascope? anyway i have 1979 924 with like 90xxx and my plan is to weld together some piping like you did and basically take the turbo system out of my talon tsi and swap it into my porsche . the turbo is mitsu 14b, if i just bolt all this up am i going to totally destroy my engine, i was planing on running like 8-9 psi, and then driving it... but everyones got me scared because i keep seeing so many idea that i have no clue about.. can i just bolt the turbo up and go? whats the worst case senario?
thanksss |
This is basically what I did. My turbo is a mitsubishi 13t from a WRX. I took a nice evening and hooked up everything. I richened my fuel system so it wouldn't detonate and I gave it hell. 8 psi on my system is excellent. What a kick in the pants on acceleration.
My setup pretty much looks like Raceboy's. The turbo is on the drivers side with exhaust running around the oil pan. _________________ 1977 Porsche 924 - going away...
2001 Audi S4 - 2.7T, Tip |
