how to make your track car very light
jesse wall
PostPosted: Thu Mar 06, 2008 1:47 pm    Post subject: how to make your track car very light Reply with quote
Well after years of trying LT found a way to make a very light car. First take it all apart , yes all apart , when you have a body with no glass doors etc all stuff out you can take out. Put the tub on a bed of sand and build a cinder block wall all aroung car ; only takes about 200! Then take kero heater gun and heat to 300plus degrees for several hours. Let car cool and you have a legal light car , not dipped , not heatd to hurt metal and very very light because every thing that is not metal is charcoal. Vaccum sandblast and prime . anyway LT read it somewhere or did it or maybe thought it up I do not know. If you want to try it let us know how it works for you . I forgot to mention, use tin or steel siding and insulation to build a sandwich and hold down with other blocks for roof please do not share this info with the 944 guys , you know how bad they cheat! they will be building light cars and putting lead in cross membe and front etc oops ! maybe I should not have said that
jesse wall 'new driver' , 87 924s
bcblase
PostPosted: Thu Mar 06, 2008 3:42 pm    Post subject: Reply with quote
Dude...slow down...use periods...complete sentences...less commas...
Maybe less caffeine?
javascript:emoticon('')
1987 Porsche 924S - track toy
1986 Mercedes 190E 2.3-16v - autocross
2007 F-150 5.4L Lariat Supercrew - tow beast
1994 Volvo 850 Race Wagon - 24 Hours of Lemons Car
2001 BMW 325xi - daily driver
924guy
PostPosted: Thu Mar 06, 2008 10:01 pm    Post subject: Reply with quote
?????? so build an oven, cook your car at 350 for four hours and melt off everything... might as well throw a turkey in there while your at it, so the Porsche and dinner will be done around the same time...
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
PostPosted: Fri Mar 07, 2008 12:40 am    Post subject: Reply with quote
Anyone else getting Terminator flashbacks?
jesse wall
PostPosted: Fri Mar 07, 2008 1:10 am    Post subject: turkey sounds good Reply with quote
I like the turkey idea,may get sponsorship from butterball?
PostPosted: Fri Mar 07, 2008 1:33 am    Post subject: Reply with quote
LOL! Yeah, 350 will only melt 'er down... 451+ will be needed to burn it up! Which I wouldn't recommend, I'd be concerned about roof brazes dying, aluminum weakening, etc...
But we will be taking another shot at taking weight out of the car this spring again... maybe more undercoating to grind off, etc... will keep all posted on the results!!
PostPosted: Fri Mar 07, 2008 1:58 am    Post subject: Re: turkey sounds good Reply with quote
I called them, they would only be interested if the car was a 944.
gla924sem
PostPosted: Fri Mar 07, 2008 11:00 pm    Post subject: oven Reply with quote
Don't think your local environmental agency would approve of the
un-controled emissions from such a bake off
darkcross
PostPosted: Wed Mar 26, 2008 5:40 pm    Post subject: Reply with quote
DIY heat treatment... I wonder if shot peening every inch of the body and chassis can be done to add structural rigidity to the body. That way, not only it is lighter, but bulletproof! Don't forget to reapply the zinc coating (I'm pretty sure the paint would peel off).
What I think Steve McQueen meant in "Le Mans" was life is all about taking risks and challenges, just like racing. And the waiting part, that's just the traffic you face every morning and noon.
Porsche 924S 2.5L
2Fast
PostPosted: Thu May 08, 2008 1:04 pm    Post subject: Reply with quote
No, mines more like this....
=====>Alex<=====
1979 Porsche 924 NA 5spd
1979 Parts Porshce 924 NA 5spd
nicoflow
PostPosted: Sun May 25, 2008 12:32 pm    Post subject: Reply with quote
here's yet another idea probabbly gona get flamed for thid one but it might work in the same manner and it is deffinatly less harmfull on the enviornment.
1. Strip the car down completely to hte steel.
2. have your local powdercoat shop bake it in their oven to remove all the crap you cant scrape off.
3. powdercoat is lighter than regular paint, so is carbon fiber.
just my 2 cents,
let me know how it turns out, it should cost about the same as building your own oven and trying to heat it.
05 Scion xB
02 Monty SS
65 MGB
