Compressor map info needed....
bruce76-924
PostPosted: Tue Feb 26, 2008 7:50 pm    Post subject: Compressor map info needed.... Reply with quote
Hi guys,
Do any of you have a compressor map for a Garrett hybrid turbo - T04B cold side with 67.5 mm compressor wheel and T3 hot side with a 64mm turbine wheel. My turbo toasted big time and I'm just toying with the idea of going for a different unit but need to see how others will compare. I was never completely happy with the Garrett as I always felt it ran hotter than it should at full boost, so maybe this is the time to change.
Cheers, Bruce.
1976 924 LHD, full cage, semi tube chassis, 951 brakes, lightweight 951 body panels.
1.8t engine conversion with Holset turbo and 6 speed Audi gearbox.
emoore924
PostPosted: Wed Feb 27, 2008 1:33 pm    Post subject: Reply with quote
Turbo maps are a little hard to find but Garrett is the easiest. They have a website someplace that has a bunch of 'em. Google what you're looking for. However, I think one for a hybrid will be a bit tougher because unless the combo you're after is something the factory is doing, there won't be a map for it. (you might get close, but...)
PostPosted: Wed Feb 27, 2008 2:28 pm    Post subject: Reply with quote
I was under the impression that a compressor map is just that: a map of a given compressor wheel, which would be independent of the turbine assembly to which it is attached. if i'm right, it shouldn't matter that you're looking at a hybrid...but I might be wrong...
bruce76-924
PostPosted: Thu Feb 28, 2008 12:07 am    Post subject: Reply with quote
Cheers Dan, I had also thought that but wasn't really sure.
Bruce.
