?????Bent valve and leaking head gasket??????
DominicT
PostPosted: Thu Oct 25, 2007 11:35 am    Post subject: ?????Bent valve and leaking head gasket?????? Reply with quote
I took my timing belt cam shaft, valve cover and head off of my 924s to find out that I have a bent valve and leaking gasket. I brought my head and cam to a machinist to clean it up put in a new valve and he puts in new gaskets all for under $100. I want to know if there is anything I can do to add HP while I have it all taken apart.
Schreiberdeutsch
PostPosted: Fri Oct 26, 2007 2:53 pm    Post subject: Reply with quote
actually yeah
I had my cylinderhead milled down to up the compression of the engine, also have your valve ports....ported and polished that is all i can think of for now....
87 924S (Wrecked)
$5,000 worth of work done to engine
1995 Mustang GT 5.0
