TINMAN
Posted: Thu Sep 13, 2007 8:12 am Post subject: |
mike: i know i was going above 70 because the pointer was firmly pegged there, and i was accelerating. as for revs i was in ... 5th gear doing around 5000? something like that. as for the hot cold thing, ill try putting it in the fridge but is that something that id only need to do once? wont after i reconnect it it just have the same problem another day.
and speedo heads? thats the face right?
as for the less than a hundred bucks rasta, that does make me feel alot better. that wouldve been a paycheck and then some
but i have to say, i was a little disheartened that while the car has good pickup, better than i initially thought, it most likely wont do over 120mph. but at least it looks and sounds good while its getting there right
as for the refrigeration plant maybe ill just put an icebox in the back and throw ice cubes at the speedo every now and then to keep it cool  _________________ The TINMAN and his TINCAN
"...When she asks... and i know she will...make sure you let her know whos Porsche it is in the driveway..."
80' 924 Burgundy |
Posted: Thu Sep 13, 2007 8:39 am Post subject: |
Hey Tinman, had a similar problem with mine which I just figured out after pulling a spare to pieces and observing what was happening while spinning it with a drill.
The speedo needle is on a shaft connected to a rotating drum with no other connection except the return spring. This shaft is only supported at two points, a nylon bearing at the base and a bronze one below the dial face. In my case the molly grease that I liberally applied to the drive cable after thoroughly cleaning it a year ago had worked its way up the cable, through the fitting and bush on the rear and built up an excess inside the speedo mechanism. A blob of thick grease was causing resistance on the drum and limit the speed, causing it to get stuck for a while.
I cleaned of as much grease as possible before using a can of degreaser and compressed air to remove it all. Then sprayed over it and the bearings with CRC (WD40, RP7 etc) to lube it all. I am sure a good clean and lube will fix it.
Oh yea, you have to dismantle it but there is info here and a link to pelican if you do a search.
Roger |
seanski44
Joined: 13 Mar 2006 Posts: 532 Location: Nottingham UK
Posted: Thu Sep 13, 2007 5:23 pm Post subject: |
| TINMAN wrote: | | ... speedo heads? thats the face right?... |
the speedo heads on ebay are the entire unit, not just the face, so you buy one and (assuming the odo isn't bust) slap it in!  _________________ 1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD |
TINMAN
Posted: Fri Sep 14, 2007 8:05 am Post subject: |
ok cool. ill take the odo apart and if thats no good, ill pick one up from ebay. also this odometer only goes to 99,999, which its already at. is that normal to be missing another number place _________________ The TINMAN and his TINCAN
80' 924 Burgundy |
Ozzie
Posted: Fri Sep 14, 2007 8:26 am Post subject: |
yep- going round the clock and restarting is normal. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Mike924
Posted: Fri Sep 14, 2007 4:32 pm Post subject: |
Comes from a time when cars weren't reckoned to last more than 100,000 miles! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Stampedetrail
Joined: 29 May 2005 Posts: 274 Location: Fairbanks, Alaska
Posted: Wed Sep 19, 2007 1:24 pm Post subject: |
| Mike924 wrote: | | Comes from a time when cars weren't reckoned to last more than 100,000 miles! |
Well the odometer on the 924 sure as hell isn't! _________________ 1977.5 924 "Martini" head / New Old Stock rebuild
1985.5 944 Why? Because I can. |
