Posted: Tue Aug 07, 2007 7:59 am Post subject: Setup Advice |
Car is understeering a bit. Here is a pic of big body roll in a 3rd gear corner.
Springs are 140, sway bar is 23mm. Changes?
rasta _________________ Toofah King Bad
Joined: 29 Jul 2001 Posts: 9070 Location: Royal Oak, MI, USA
Posted: Tue Aug 07, 2007 8:06 am Post subject: |
You can probably gain a bit more control with alignment changes - what're your current settings?
But ultimately, to significantly reduce that body roll, you need to increase your roll rate, period - either stiffer sways or stiffer springs/t-bars. Springs and t-bars will probably be cheaper, at least for new parts, but more work to install. _________________ Vaughan Scott
genikz88
Posted: Tue Aug 07, 2007 9:10 am Post subject: |
That's not too bad actually. Here is my '88 924S with 400lb front springs and 30mm torsion bars (stock front anti-roll bar and Welt 22mm rear). Your car isn't leaning much farther.
As far as understeering, maybe try playing with your tire pressures. Also, an alignment is crucial. Lastly, a bigger rear anti-roll bar will induce more oversteer, which in my case helps the car rotate and makes understeer much less of a problem. _________________ Chris
'88 924S |
steeny
Joined: 24 Nov 2005 Posts: 319 Location: Brisbane, Australia
Posted: Tue Aug 07, 2007 10:11 am Post subject: |
Rasta, for that corner, you could always try putting the driver on the correct side of the car.  _________________ 1978 924 N/A
she's gone..... |
Posted: Tue Aug 07, 2007 11:59 am Post subject: |
Are you implying that my personal mass is influencing Shaggy's handling?
geni, you got 15s up front and 16s in the rear? Crazy! _________________ Toofah King Bad
Posted: Tue Aug 07, 2007 12:32 pm Post subject: |
Until you get it corner balanced.... _________________ White 87 924S "Ghost"
genikz88
Posted: Tue Aug 07, 2007 3:02 pm Post subject: |
| Rasta Monsta wrote: | | geni, you got 15s up front and 16s in the rear? Crazy! |
Must be an illusion...they're all 15x7 _________________ Chris
'88 924S |
John Brown
Posted: Thu Aug 09, 2007 5:57 am Post subject: |
Put the 968 19mm adjustable (some) in the rear. Paragon sell them. Not perfect but about all you can do without spending some semi-serious money. Assuming you have the 'standard' 14mm you could also install an 18mm. Someone should have one for the low side of $100. _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
Posted: Thu Aug 09, 2007 7:27 am Post subject: |
i have the same understeering problem here...i guess that you could trick it a bit by deflating the front tyres a bit....at least thats what i'm thinking now after a few beers  _________________ Supercharger and EFI kits
https://www.the924.com |
!tom
Posted: Thu Aug 09, 2007 8:17 am Post subject: |
I'd rather air up the rears than deflate the fronts.
That does nothing for the body roll, which will slow the handling response and increase weight transfer.
Tire pressure is a fine tuining aid -- it doesn't replace sway bars and springs.
Street tires can be safely run far above their maximum pressure rating, but if you lower the pressure much, they start to handle poorly. _________________ 78 924 NA
5-lug |
Posted: Thu Aug 09, 2007 9:06 am Post subject: |
| John Brown wrote: | | Put the 968 19mm adjustable (some) in the rear. |
I am running that bar currently, set on full stiff, with an M471 23mm up front. _________________ Toofah King Bad
StienbargerR
Posted: Thu Aug 09, 2007 9:45 am Post subject: |
wouldn't stiffening the rear just make it understeer more?
Ryan _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
!tom
Posted: Thu Aug 09, 2007 9:55 am Post subject: |
| StienbargerR wrote: | | wouldn't stiffening the rear just make it understeer more? |
Nope.
As discussed elsewhere, a stiffer rear sway bar will loosen the car, or give it oversteer, depending on the terminology you want to use. _________________ 78 924 NA
5-lug |
StienbargerR
Posted: Thu Aug 09, 2007 10:12 am Post subject: |
oh. I stand corrected.
Posted: Fri Aug 10, 2007 9:30 pm Post subject: |
Hm. As Scott said, check your alignment, maybe try som more track friendly settings. My car was very netutral before, but as the tires started to wear out it passed over to the oversteer side. Just a little bit, but still pretty fast.
The key is to have real rubber on your wheel. If you have planned to track drive more than one time i suggest buying a set of "r-compund" tires, not really sure what you call them. Really stiff sidewalls helps alot, and they do not overheat. Current set up is about -3 degrees of negative camber. After i changed camber i gained ALOT of front end grip. But i´m to lazy to change rear. Its about -1.2 degrees. That is a cheap way of getting fast around the tracks. _________________ 1980 924 Turbo
