Hatch Reseal
Ozzie
PostPosted: Wed Mar 21, 2007 2:41 pm    Post subject: Reply with quote
Dont it look similar
http://graduate.gradsch.uga.edu/archive/Fuego.html
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Wed Mar 21, 2007 3:22 pm    Post subject: Reply with quote
Similar's one thing... "fits" is another!
Gavin.
-nick
PostPosted: Wed Mar 21, 2007 4:00 pm    Post subject: Reply with quote
Weird. Check out the page 3 shot of the rear. Aren't those 924/944 taillight assemblies and a 924/944 rear Euro bumper?
http://graduate.gradsch.uga.edu/archive/rt_fuego.pdf
1980 931S
1991 964 C4 Cabriolet
PostPosted: Wed Mar 21, 2007 4:31 pm    Post subject: Reply with quote
Wow, over 100 HP on a 1.5 Turbo?? It really is En Fuego.
PostPosted: Wed Mar 21, 2007 8:00 pm    Post subject: Reply with quote
its just a joke guys its different.
anyway regarding the engine..its a disaster...turbocharged 1.5L that produces 120 NM of torque ? haha the 1.6 NA VW engine has 118 NM.
Nobbi
PostPosted: Fri Mar 23, 2007 1:50 am    Post subject: Reply with quote
hey ,
in that renault its just installed up-side-down.Means,the hinges on our part are on the renault back side.The glass it self is the same.
keep in mind that there is no hole for the wiper......
Nobbi
PostPosted: Fri Mar 23, 2007 3:39 am    Post subject: Reply with quote
Nobbi wrote:
hey ,
Nobbi
you are kidding...right ???
Nobbi
PostPosted: Tue Mar 27, 2007 6:37 am    Post subject: Reply with quote
No,
no kidding,i read this in a porsche mag years ago.
Nobbi
Tigger937
PostPosted: Sun May 27, 2007 1:32 pm    Post subject: Reply with quote
I was able to repair mine 2 years ago without removing the glass. As I recall, it was a 3 step process using 3M Window Weld (there are also small bottles of a 3M cleaner and a primer that need to be purchased separately, NAPA has them). Just followed the instructions on the tube.
Part #'s here: http://www.924board.org/viewtopic.php?t=16842&highlight=hatch
It's important to get the surfaces clean first. PATIENCE REQUIRED. With the hatch open, I just stuffed some wooden spacers between the glass and frame to pry it up a little along the roof line at the top. Then I was able to take a cloth soaked in cleaner and rub it between the two surfaces with my finger. Let it dry. I think at this point, the instructions called for roughing up the surfaces. Then applied the primer, let dry and finally applied the Window Weld. Lastly, I carefully let the hatch down (did not close it) and put weights on the top of the glass along the roof line to apply pressure during the overnight drying process. Total time was about 2 hours (just make sure you understand the whole process before getting started. The primer and glue dry rather quickly and there is no doing it over). Next morning, I removed the weights, checked and confirmed the glue was dry and closed the hatch. No more problems.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
gla924sem
PostPosted: Wed Jun 20, 2007 2:08 am    Post subject: hatch Reply with quote
Just had my hatch redone here in the Detroit area by a local glass shop.
Did one great job for $200
No more worries about glass separation for a long time.
PostPosted: Wed Jun 20, 2007 4:33 am    Post subject: Reply with quote
WIMP!
By the way, I have the sealant, primer and adhesive remover for this job, unused and available for sale it anyone is interested.
gla924sem
PostPosted: Thu Jun 21, 2007 2:57 am    Post subject: rear hatch Reply with quote
Call me what ever but its done and done without breaking the glass!!!!
Tigger937
PostPosted: Thu Jun 21, 2007 8:02 am    Post subject: Re: rear hatch Reply with quote
I think that comment was intended for me. Same response applies though.
1981 931 (Concours)
PostPosted: Wed Mar 16, 2011 5:47 am    Post subject: Reply with quote
Evidence this job is actually possible:
SolReaver - Pelican.
PostPosted: Wed Mar 16, 2011 8:36 am    Post subject: Reply with quote
Seriously, why would you want to pry on glass with a hard object? That rasta-herb must be fogging your thoughts.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
Page 2 of 3
