NBRettie18
Joined: 21 Jan 2006 Posts: 111 Location: Santa Barbara, California
Posted: Thu Mar 29, 2007 9:29 am Post subject: no lights when drivers door open |
The lights inside my car and the trunk do not come on when the drivers door is open but they do come on when the passengers door is open. Both of the lights work fine just now for the drivers door. Anyone had this problem? _________________ 1987 924S - MO30 30/19 - Yellows all around |
Posted: Thu Mar 29, 2007 9:48 am Post subject: |
its probably the door switch...check it...replace it. _________________ Supercharger and EFI kits
https://www.the924.com |
Posted: Thu Mar 29, 2007 12:24 pm Post subject: |
Yep, I have had 2 924s and two bad driver's side switches. _________________ Toofah King Bad
NBRettie18
Posted: Thu Mar 29, 2007 1:22 pm Post subject: |
where is the door switch located? Is it the switch that makes the ding noise to let you know the doors open? cause if so that works, at least it makes the ding noise. _________________ 1987 924S - MO30 30/19 - Yellows all around |
Eagle924S
Joined: 14 Nov 2006 Posts: 19 Location: Cincinnati, Ohio, USA
Posted: Thu Apr 05, 2007 8:32 am Post subject: |
Sometimes the lights do not come on when i open the drivers door. Sometimes they do. The switch in the door sometimes get stuck. _________________ 87 924S |
NBRettie18
Posted: Wed Apr 25, 2007 6:16 am Post subject: |
Yea mine never come on with the drivers door though, but they always come on with the passenger side. Also when the key is in the ignition the warning alram noise does come on when the drivers door is open. _________________ 1987 924S - MO30 30/19 - Yellows all around |
Posted: Wed Apr 25, 2007 8:44 am Post subject: |
I don't know if the 924S wiring is the same, but on my '82, the left door switch is a double-pole (DPST) design with one pole operating the light and the other pole triggering the seatbelt warning (4th page of the '82 wiring diagrams). -So it could still be a half bad switch or a problem with the wiring to half of it. Usually a simple switch like that can be taken out, cleaned with sandpaper (the contacts), lubed with silicone dielectric gel and put back together. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Wed Apr 25, 2007 11:01 am Post subject: |
In my car, the center dome light right by the windshield, has a switch, you can switch it so its always on, on when door is open and never on. It couldn't be that the light switch is in the wrong spot?
It wouldn't be unheard of that it switched itself, its happend to me.  _________________ [This Space For Rent] |
Vince Ponz
Posted: Wed Apr 25, 2007 11:48 am Post subject: |
You can always exit out the pass side. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Mike924
Posted: Wed Apr 25, 2007 5:56 pm Post subject: |
The switch is located in the front door jamb. It looks like a small oval metal plate with a rubber surround, held in place by a singe cross-head screw.
If your car has a door open warning alarm, the switch will be a two-pole job as Smoothie says. If you're not fussed about having a door alarm (and it's not a legal requirement where you are), you can swap the two wires at the back of the switch, but new switches are cheap and readily available, as they're used on a lot of VW cars. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Eturbo924
Joined: 09 Nov 2002 Posts: 2212 Location: Londonderry NH
Posted: Tue May 01, 2007 10:49 pm Post subject: |
Also some times the area corrodes a bit and the connection is not as good as it should be. Take the switch out. Wire brush the screw that is used to mount it and clear the area around the screw hole of any corrosion and such. Also any excessive paint. Clean all the wire connections and put it back in. See if it works then. I solved on that way. _________________ 1982 924
1992 968
2003 C4S
Parts Parts Parts and More parts.
E-mail me for parts you need!
Drive Fast! |
Posted: Wed May 02, 2007 1:57 am Post subject: |
oh..the damn thing stoped working over here too ! i'll go check it right now and then post if i find the problem. _________________ Supercharger and EFI kits
