pitted lifters
friskynibbles
Guest
PostPosted: Mon May 27, 2002 11:57 am    Post subject: Reply with quote
got my engine apart today and found that *all* the intake lifters were pitted on the top - the front two were the worst and the back two were hardly touched. what might cause this? i should replace 'em right? everything else looks fine but we haven't measured the block yet. the pistons also look great - one of them is sparkly clean from a steam cleaning it got courtesy of a blown headgasket?
friskynibbles
Guest
PostPosted: Mon May 27, 2002 2:50 pm    Post subject: Reply with quote
somebody, please, hhhhhhelp meeeeeee!
i need to get this car on the road.
wdb
Guest
PostPosted: Mon May 27, 2002 4:17 pm    Post subject: Reply with quote
the damage is caused by them being hit on the head 1500 times a minute for the last 20 years, yes replace them, less damaged one may be repairable.
gohim
Guest
PostPosted: Mon May 27, 2002 4:22 pm    Post subject: Reply with quote
Your pitted cam followers are most probably the result of inadequate lubrication, poor oil change scheduling, and/or poor maintenance.
The Camshaft Oil Tube should be inspected and cleaned everytime the valve cover is off.
Debris from the oil system plugs the holes in the oil Tube, and the cam bobes are deprived of oil. Then, the cam lobes grind the cam followers. Dirty oil leaves contaminants on the tops of the cam followers which causing corrosion on the tops of the cam followers causing pits.
The plastic elbow that connects/seals the Camshaft Oil Tube to the cylinder head should be replaced each time as well. The plastic elbows shrink with age and oil flow that should be delivered to the cam lobes get lost when the plastic elbow get loose, and leak.
friskynibbles
Guest
PostPosted: Mon May 27, 2002 4:42 pm    Post subject: Reply with quote
why just every second follower tho?
why not all of them?
Joes924
Guest
PostPosted: Mon May 27, 2002 8:21 pm    Post subject: Reply with quote
You know I never have cleaned the oil tube on my running car the tops are fine though
,I cant waite to see what the under neath of the head looks like &the pistons also.
friskynibbles
Guest
PostPosted: Tue May 28, 2002 2:05 am    Post subject: Reply with quote
how much of a pain in the ass is it to take out those valves to have them cleaned up?
Guest
PostPosted: Tue May 28, 2002 2:24 am    Post subject: Reply with quote
well to remove the vavles to have them ground or cleaned you have to remove the head, but if you mean to remove the tappets off the top of the valves to clean them just remove the cam make sure you get the journals in the right order when you put it back on but once the cam is off just pull the tappets up and they should come if they dont come with ease grab them with a pair of channel lock pliers and a cloth so you dont damage them even more and they will lift off to be repaired.
friskynibbles
Guest
PostPosted: Tue May 28, 2002 2:40 am    Post subject: Reply with quote
the head's already off. that's how i saw the pistons.
coconutcowboy
Guest
PostPosted: Mon Jun 03, 2002 2:34 pm    Post subject: Reply with quote
hard chrome or hard nickle plate them back to specs.
See my threads by searching coconutcowboy under the user search feature on this site.
Sean Ross A@P
