Fuel Pump
LeeXIX
PostPosted: Fri Sep 22, 2006 7:43 am    Post subject: Fuel Pump Reply with quote
Well I just got off the phone with Performance Products and found that the fuel pump is on intergallactic backorder. Any ideas where I can get a fuel pump for my '77 (build date of 9/76) for a bit more reasonable price than 600 USD? It is a single pump mounted outside of the tank. I called a few local suppliers (I work for a Chrysler/Jeep dealer and have a few contacts) but no luck so far.
Since mine is an early I may be forced to consider going to carburation. But I haven't been able to find even a manifold listed for it.
Any ideas???? Please let me know
Thanks
I have a 924 (yellow) Porsche since I lost my 1971 914 in my divorce. She threw out everything except the shell of the body.
PostPosted: Fri Sep 22, 2006 9:48 am    Post subject: Reply with quote
Some guys have found used ones real cheap.....I've heard rumors the VW CIS pumps can be used with some on site engineering.
At one point Joe had a work bench full of them.
dpw928
PostPosted: Fri Sep 22, 2006 11:19 am    Post subject: Reply with quote
Pierberg makes pumps that have multiple adapters for different cis configurations. New and used Bosch pumps that work with the early cis 928's are available from www.928intl.com . The pumps with the internal check valve should/may work on your 77.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
PostPosted: Fri Sep 22, 2006 10:14 pm    Post subject: Reply with quote
Like Dennis said; I have successfully used the Pierburg pump on an early car.
They're also a lot cheaper and more reliable than Bosch ones.
Eturbo924
PostPosted: Fri Sep 22, 2006 10:21 pm    Post subject: Reply with quote
Same here I got one and they came already with the correct adaptors on it.
Eric
1992 968
2003 C4S
Parts Parts Parts and More parts.
E-mail me for parts you need!
Drive Fast!
NEMESIS
Good info and prices here...http://www.924board.org/viewtopic.php?t=16690&highlight=fuel+pumps&sid=0d6c97d499efe6dbb1a6f7aae2e7391a
Nobbi
PostPosted: Sat Sep 23, 2006 6:29 am    Post subject: Hello Folks, Reply with quote
Heres a web site where you can find almost any part for any car and-
you can see on which other modell or car it fits to.
goto www.autoteile.cc check on right for model,select porsche then 924 plus right production year.The choose engine or Brakesystem or whatever from list and you get a couple of choices. For a 1/1976 to a 6/1985 car you can choose 5 diffrent fuel-pumps! Bosch for 585,80 Euros or Ruville for 168,44 Euros. Telephone and fax numbers are visible when you click on the OEM Name which is highlighted.
Hope i could help, Nobbi
justinw77
PostPosted: Sat Sep 23, 2006 12:51 pm    Post subject: Fuel Pum Reply with quote
Hey, I just found a used Bosch fuel pump on Ebay for $100 and just from searching the internet I found several of them for under $200 brand new. Just try a broad search on any search engine and take the time to browse. If you still cant find anyting just write me a message and Ill let you know the exact websites I looked at.
1982 Porsche 924 Targa
