How to quiet a BOV?
-nick
PostPosted: Tue Jul 04, 2006 2:22 am    Post subject: How to quiet a BOV? Reply with quote
It sounded cool the first few times, now it's just loud and obnoxious
I'm running it open to atmosphere. Plumbing it to recirculate would be a really big pita. What other option is there to quiet it down?
I'm running a Forge Motorsports valve that you can see here:
It doesn't have a horn or any other sound-increasing gizmos. It's just plain old loud.
ps- at idle I have positive pressure coming out of it - telling me that the turbo is pushing more air than atmospheric even at ~1100 rpm. Is this normal?
nick
OutOfTheBox
PostPosted: Tue Jul 04, 2006 3:30 am    Post subject: Reply with quote
stick a sock in a coke can and away you go
sound is high frequency
high frequency = very directional & bounce off hard stuff.
turn the dump the other way, make whatever comes out hit a soft something.
sponge would be better than an airfilter
endwrench
PostPosted: Tue Jul 04, 2006 3:30 am    Post subject: Re: How to quiet a BOV? Reply with quote
You can either recirculate it into the intake or you can do what I am goint to do and build some sort of "muffler" for it. You don't know what load is until you've heard mine!!
[quote]ps- at idle I have positive pressure coming out of it - telling me that the turbo is pushing more air than atmospheric even at ~1100 rpm. Is this normal?
[\quote]
Is this a bad thing!?
Todd
RIPDOTCOM
PostPosted: Tue Jul 04, 2006 4:34 am    Post subject: Reply with quote
best way is to recirculate or buy a quieter bov
bass gt
PostPosted: Mon Jul 10, 2006 8:48 am    Post subject: Reply with quote
Nick,
It seems you have a recirculating type of BOV. I believe these will allow recirc under low load conditions, clamping shut once the boost rises sufficiently. You need to either plumb it in or change it to an atmos dump type.
I am thinking of fitting a re circ type to my racer, but i'm going to speak to Bailey motorsport tomorrow to get some advice.
Steve
P924
PostPosted: Tue Jul 11, 2006 2:40 am    Post subject: Reply with quote
What an engine... WONDERFUL
911T 2.2
Raceboy
PostPosted: Tue Jul 11, 2006 3:45 am    Post subject: Reply with quote
This actually is bypass valve not BOV indeed.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
endwrench
PostPosted: Tue Jul 11, 2006 2:08 pm    Post subject: Reply with quote
Don't they both function the same? Difference is one is plumbed back to the intake and the other to the atmosphere?
Todd
Mr_Bob
PostPosted: Fri Aug 25, 2006 7:38 pm    Post subject: Reply with quote
Put a pcv filter on it.
-nick
PostPosted: Sat Aug 26, 2006 3:04 am    Post subject: Reply with quote
Despite your unnatural love for carburetors, this is actually a good idea Cheers!
Dagwood928
PostPosted: Sun Sep 03, 2006 10:19 am    Post subject: Reply with quote
I think if you even put a pipe on the end put a bend in it and vent it down out the bottom of the engine compartment, you could effectively change the frequency and dampen the noise a bit......kind of like long straight pipes on an exhaust.
2 cents
Darren
-nick
PostPosted: Fri Oct 06, 2006 3:11 am    Post subject: Reply with quote
Solved
With some help from Mike Lombardi @ Forge Motorsports (great guy!). He told me that facing the valve in the stock direction makes a higher pitched sound than if you simply swap the inlet/outlet sides.
I made the change, and also stuffed a clean shop rag into a cheap breather filter that the outlet is plumbed into. Now I just get a very faint, and very acceptable, "pshh" as opposed to the mind-jarring "PSSTTT" that would echo off houses on residential streets!
Not a boost spike to be found even with the rag damping the sound.
1980 931S
1991 964 C4 Cabriolet
