924 Transmission
Cbass
Guest
PostPosted: Wed May 15, 2002 3:13 pm    Post subject: Reply with quote
I have two questions.
1)What would it cost to put new synchros in a 79 snaishell transmission?
2)What are the factory numbers for the transmissions? I know the 931 snailshell is the G31. Is the 924 snailshell the G24?
What about the Audi boxes?
Diesel
Guest
PostPosted: Wed May 15, 2002 10:04 pm    Post subject: Reply with quote
Geez, I've got a snailshell from the 79 Euro I parted out that I can't get rid of! The thing shifted OK and everything but nobody seems to want it. Well, I take that back, one guy wanted to remove it for free. I told him I'd use it as a mailbox post before I GAVE it away.
Vince Ponz
Guest
PostPosted: Wed May 15, 2002 11:49 pm    Post subject: Reply with quote
Email me off the list for the tranny. I don't need it now but I could use it soon. How much so email me off the list.
Diesel
Guest
PostPosted: Thu May 16, 2002 3:37 am    Post subject: Reply with quote
Mail on the way.
Rick MacLaren
Guest
PostPosted: Thu May 16, 2002 3:52 am    Post subject: Reply with quote
$120.00 CDN to $150.00 CDN a pop. Priced it just a few months ago.
[ This Message was edited by: Rick MacLaren on 2002-05-18 03:50 ]
gohim
Guest
PostPosted: Thu May 16, 2002 5:05 am    Post subject: Reply with quote
088 YR Row four speed
088 XT US/Japan four speed
016Z RoW snail for 924
016Y US snail for 924
016/8 RoW Audi five speed for 924
sub-versions VQ,MD,4Q
016/9 US Audi five speed for 924
sub-versions VR,MF,5Q,ME
G31/01 RoW snail for 931
G31/02 US snail for 931
016J RoW 944, WW 944, RoW/WW 924S
sub-versions QK,7Q,5Y,5Z,7V,5S
016K US 944
016G MB US Audi for 931
016G MX Japan Audi for 931
numbers
Guest
PostPosted: Thu May 16, 2002 5:55 am    Post subject: Reply with quote
It depends on what you are calling a snychro. If you just want new synchronizer rings, they cost about $100 US each, plus installation. That is all you will need if you haven't been grinding the gears too long. If you have been grinding gears, your dog teeth will be shot on the gears you have been grinding, and to the best of my knowledge, they are not available as a seperate unit. So, you have to by new gear sets for the effected gears. The last gear set that I bought cost me $1400.00.
Cbass
Guest
PostPosted: Thu May 16, 2002 10:24 am    Post subject: Reply with quote
Gears are still good, I think. I'll have good looksee at the dog teeth. I'm trying to decide whether or not to rebuild or replace, whichever is more cost effective. For the prices I'm seeing thrown around here, I could get a 968 tranny.
$100 a piece for the rings? Doesn't sound that bad for total cost.
Thanks for the codes Gohim
John H
Guest
PostPosted: Thu May 16, 2002 11:13 am    Post subject: Reply with quote
You left out the GT gearbox code which is G1/03 from memory
PostPosted: Thu May 16, 2002 12:29 pm    Post subject: Reply with quote
Yeah, the synchro rings I got were about $100 each, and yes, the big thing is the condition of the dog teeth.
Cbass
Guest
PostPosted: Fri May 17, 2002 7:19 am    Post subject: Reply with quote
Okay, what should the dog teeth look like? Where should I see signs of wear?
numbers
Guest
PostPosted: Fri May 17, 2002 7:24 am    Post subject: Reply with quote
The dog teeth stick out from the side of the gear and look like a bunch of really tiny piramids. They are about 1/16 of an inch high. If they are worn, the tops of the piramids will be missing.
Cbass
Guest
PostPosted: Fri May 17, 2002 9:29 am    Post subject: Reply with quote
So I just make sure they are good and pointy? Is it okay if they are slightly rounded, or do they have to sharp?
AppleBit
PostPosted: Fri May 17, 2002 10:32 pm    Post subject: Reply with quote
CBass, buy my snailshell tranny from me! I have no use for it! The housing was cracked when it got pulled (literally) out of the car. Everything was sound with it otherwise... Make me any offer! I am in Minnesota so not too far away from the border
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
Diesel
Guest
PostPosted: Sat May 18, 2002 5:20 am    Post subject: Reply with quote
Somebody buy my snailshell from me!
[ This Message was edited by: Diesel on 2002-05-19 00:28 ]
