Cbass Guest
Posted: Thu May 16, 2002 10:29 am Post subject: |
| The time involved doesn't concern me a great deal. So you figure around $400 total? |
Cbass Guest
John H Guest
Posted: Thu May 16, 2002 4:23 pm Post subject: |
cbass,
I've mentioned it in another thread - if you're going to do the synchro's try to replace the dog teeth as well as the brake bands and the sliding sleeve.
2nd gear dog teeth are hard to find but 3 to 5 are 915 type. As a last resort if 4th is notchy then you can take the dog tooth off and put it on 5th and 5th onto 4.
I did this with mine about 10 years ago and replaced the brake bands and sleeves. Box has done 10 seasons racing and still going strong - it also gets used as an every day car (260,000 miles) so unless you can get all the peices cheap or free I'd stick to the snail shell
[ This Message was edited by: john h on 2002-05-17 07:27 ] |
Cbass Guest
Posted: Fri May 17, 2002 7:25 am Post subject: |
The synchro for 2nd is shot, I don't know whether it's the ring or the dog teeth. Is there a tranny rebuild document you know of?
What I might just do is replace the 2nd gear synchro ring, and drive it as such until I get a 931 tranny and torque tube for the 5 cyl. |
numbers Guest
Posted: Fri May 17, 2002 8:06 am Post subject: |
| The ring is what is causing your problem, but the dog teeth may be worn if you or the PO did much gear grinding after the ring started slipping. |
