-nick
Posted: Tue Jul 04, 2006 2:22 am Post subject: How to quiet a BOV? |
It sounded cool the first few times, now it's just loud and obnoxious
I'm running it open to atmosphere. Plumbing it to recirculate would be a really big pita. What other option is there to quiet it down?
I'm running a Forge Motorsports valve that you can see here:
It doesn't have a horn or any other sound-increasing gizmos. It's just plain old loud.
ps- at idle I have positive pressure coming out of it - telling me that the turbo is pushing more air than atmospheric even at ~1100 rpm. Is this normal?
nick |
OutOfTheBox
Posted: Tue Jul 04, 2006 3:30 am Post subject: |
stick a sock in a coke can and away you go
sound is high frequency
high frequency = very directional & bounce off hard stuff.
turn the dump the other way, make whatever comes out hit a soft something.
sponge would be better than an airfilter |
endwrench
Posted: Tue Jul 04, 2006 3:30 am Post subject: Re: How to quiet a BOV? |
| -nick wrote: | It sounded cool the first few times, now it's just loud and obnoxious
You can either recirculate it into the intake or you can do what I am goint to do and build some sort of "muffler" for it. You don't know what load is until you've heard mine!!
[quote]ps- at idle I have positive pressure coming out of it - telling me that the turbo is pushing more air than atmospheric even at ~1100 rpm. Is this normal?
[\quote]
Is this a bad thing!?
Todd |
RIPDOTCOM
Joined: 17 Mar 2006 Posts: 57 Location: Tallahassee, Florida
Posted: Tue Jul 04, 2006 4:34 am Post subject: |
| best way is to recirculate or buy a quieter bov |
bass gt
Posted: Mon Jul 10, 2006 8:48 am Post subject: |
Nick,
It seems you have a recirculating type of BOV. I believe these will allow recirc under low load conditions, clamping shut once the boost rises sufficiently. You need to either plumb it in or change it to an atmos dump type.
I am thinking of fitting a re circ type to my racer, but i'm going to speak to Bailey motorsport tomorrow to get some advice.
Steve |
P924
Posted: Tue Jul 11, 2006 2:40 am Post subject: |
What an engine... WONDERFUL  _________________ 924 1981
911T 2.2 |
Raceboy
Posted: Tue Jul 11, 2006 3:45 am Post subject: |
This actually is bypass valve not BOV indeed. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
endwrench
Posted: Tue Jul 11, 2006 2:08 pm Post subject: |
| Raceboy wrote: | | This actually is bypass valve not BOV indeed. |
Don't they both function the same? Difference is one is plumbed back to the intake and the other to the atmosphere?
Todd |
Mr_Bob
Posted: Fri Aug 25, 2006 7:38 pm Post subject: |
Put a pcv filter on it.
-nick
Posted: Sat Aug 26, 2006 3:04 am Post subject: |
Despite your unnatural love for carburetors, this is actually a good idea Cheers! |
Dagwood928
Posted: Sun Sep 03, 2006 10:19 am Post subject: |
I think if you even put a pipe on the end put a bend in it and vent it down out the bottom of the engine compartment, you could effectively change the frequency and dampen the noise a bit......kind of like long straight pipes on an exhaust.
2 cents
Darren |
-nick
Posted: Fri Oct 06, 2006 3:11 am Post subject: |
Solved
With some help from Mike Lombardi @ Forge Motorsports (great guy!). He told me that facing the valve in the stock direction makes a higher pitched sound than if you simply swap the inlet/outlet sides.
I made the change, and also stuffed a clean shop rag into a cheap breather filter that the outlet is plumbed into. Now I just get a very faint, and very acceptable, "pshh" as opposed to the mind-jarring "PSSTTT" that would echo off houses on residential streets!
Not a boost spike to be found even with the rag damping the sound. _________________ 1980 931S
1991 964 C4 Cabriolet |
