Topend its goin..
Joes924
PostPosted: Thu Apr 25, 2002 11:00 am    Post subject: Reply with quote
Got thethrottlebody from someone on the board,theintake & head from european car clinic... header from somewhere ..getten excited cam arrived at schneider onthe 22nd.
should be done.
http://home.attbi.com/~joedanka/topend_2.jpg
http://home.attbi.com/~joedanka/porsche1/stthrotbody.JPG
http://home.attbi.com/~joedanka/porsche1/eurothrot.JPG
I was going to go with the sleeve out then I found this big one so Im gonna experiment..
http://home.attbi.com/~joedanka/bigbore.JPG
924Porsche1979JoeD.
[ This Message was edited by: joes924 on 2002-05-06 14:17 ]
[ This Message was edited by: Joes924 on 2002-05-22 16:48 ]
JvGinPDX
PostPosted: Thu Apr 25, 2002 11:06 am    Post subject: Reply with quote
Joe, I took the sleeve out, and it makes a considerable difference in how the car acts at low speeds. I cut out the sleeve in a79 TB. a copper tube pressed in from the side prevents easy removal. But when I felt around in my 77 TB, it came out with a slight tug, pulling from back to front. Free is a very good price.
Joes924
PostPosted: Thu Apr 25, 2002 12:06 pm    Post subject: Reply with quote
Jvpdx so do you still have it out or do you like it ..Was it good that you removed it is what I mean
JvGinPDX
PostPosted: Thu Apr 25, 2002 3:52 pm    Post subject: Reply with quote
Joe, I still run my car without the insert. It seems to do better in town, and on the road. And it still passes Oregon emission tests.
Joes924
PostPosted: Thu Apr 25, 2002 6:04 pm    Post subject: Reply with quote
Ive noticed that I dont have to do any port matching between it[thrott. body] &intake
wonder if theres one out there with a bigger
2ndary.. e-turbo back east way back there
did alot of removal of metal between the 2.
Maybe theres a bigger one out there.. some
Ive found the mounting holes dont match up
[spaced out farther lengthwise]
Ive had better luck, seeing bigger ones
[if I remember correctly]on rabbits than
4 door audi 5000s, guess Ill look again
when I have time, got to go back to work
Thur. Weekends are kind of full but still
where I have the most time..He used a audi unit ..I think,gonna have to check his page
to be sure.
Joes924
PostPosted: Sun Apr 28, 2002 11:58 am    Post subject: Reply with quote
Got up Saterday early and started ,grinding and polishing &cleaning all this stuff by 6am.
Ill sand blastheader next saterday and start on valves I think..
http://home.attbi.com/~joedanka/porsche1/topend2.JPG
Joes924
PostPosted: Mon May 06, 2002 2:07 pm    Post subject: Reply with quote
So the shims just sit on top of the valve inbetween it & the adjusting screw in the bucket.
