Khal
Posted: Mon Jan 16, 2006 5:05 am Post subject: |
| Belgian924t wrote: | | I think it is more interesting to buy a real 924 turbo |
Yeah, I tend to agree.
I'm a little lost with this one. What exactly is it you want, Keaton?
Have you got your heart set on an engine transplant? Are you a hot-rodder? (I have no problem with that, not implying it's a bad thing, just wondering)
Or do you just want your 924 to have more power?
The reason I ask is that it's dead-set simple, relatively speaking, to make a pretty hi-po 924... you just buy a 931 and add an intercooler and up the boost. It's been done many times by members here. It works and it's relatively cheap and easy. Buying a 931 and doing this upgrade will probably be cheaper overall than doing an engine swap in your NA 924.
And you've mentioned previously that there's some sentimental value in your car. That being the case, I'm surprised you're so willing to consider butchering it...
| Keaton wrote: | | i'm looking for a 5 cyclinder with a turbo that shares the same bell house bolt patteren as the stock motor in the 924. from what i have read the American is good for 325 HP at the fly wheel(on stock turbo and valve train). |
You can't just dump a 300+ hp engine into a 924! You'll get yourself killed!
Well, actually, probably not 'cause you'll tear the drivetrain to shreds before you get anywhere...
But God help you if you do actually get the thing rolling
Think about it, kid. You're gonna hafta upgrade everything. Clutch, torque tube, transmission, diff, brakes, suspension, etc... _________________ '80 924 Turbo |
sequential
Posted: Mon Jan 16, 2006 5:33 am Post subject: |
Hmmmm an audi 5 cyl to replace the audi 4 cylinder , sounds reasonable , does that now make it a 925! _________________ 928 gts prototype
baby blue engine block
steam in 1,2,3,4 sometimes
cold star issues while on stands
112 whp with new 4 valve head and MIS 2 |
CBass
Joined: 03 Nov 2002 Posts: 2807 Location: Vancouver, Canada
Posted: Mon Jan 16, 2006 5:44 am Post subject: |
Actually, do a search for posts by 925turbo on the board.
He was a board member from Sweden, he put a 10v turbo 5 cylinder in his 924. It required a bit of custom fabrication on the exhaust, IIRC, but he believed that a DOHC 20v 5 cylinder would clear the intake and exhaust without issues, as it is a crossflow motor. He had to fabricate his own motor mounts as well.
As for EFI, gonig from one Audi CIS engine to another is not a big deal wiring wise. I'd get teh CIS engine running in the car and work out the mechanical issues before messing around with management and tuning.
Looking at the 20v, I'm not sure if the stock wastegate would clear easily, you might still need to make a new exhaust manifold.
http://924board.org/viewtopic.php?t=3976&highlight=cylinder&sid=57dccbf00f897e957de0f264d7e9d3d6 _________________ '81 931 in various states of assembly |
moone924
Joined: 05 Feb 2003 Posts: 868 Location: Douglas Wyoming
Posted: Mon Jan 16, 2006 8:24 am Post subject: |
Keaton.... Those 20v 5 Cyl's are big bucks.... you might as well buy a 944 Turbo. _________________ Ryan Moone
Always shopping for a nice s2 931 to baby.
New philosophy : one car project at a time. |
Posted: Mon Jan 16, 2006 8:31 am Post subject: |
| sequential wrote: | | Hmmmm an audi 5 cyl to replace the audi 4 cylinder , sounds reasonable , does that now make it a 925! |
It's a turbo so maybe it's a 935....I guess that one is already taken? _________________ White 87 924S "Ghost"
Belgian924t
Posted: Mon Jan 16, 2006 8:53 am Post subject: |
With all respect, but the 935 is one of the most important Porsches in the manufacturer's history...Also in the global racing history.
Greetz... _________________ '79 931 with Carrera GT look
'86 944 turbo (sold)
'88 944 turbo S (sold)
'85 911 Carrera 3,2 (to be restored)
'80 911 SC "SOLD"
http://www.cardomain.com/ride/2224272 |
Posted: Mon Jan 16, 2006 10:49 am Post subject: |
OF COURSE!
No offense intended to Moby Dick:
ESC944
Posted: Fri Jan 20, 2006 4:51 pm Post subject: |
AUDI PERFORMANCE AND INFORMATION
You could change the heads and mate a 10v block with the 20V head, but its some work.
http://2bennett.com/
http://www.toxcheap.com/
Hit up http://www.motorgeek.com/ for some excellent Audi engine answers.
If you want to go 20vt, try to find a complete 20vt engine, or do the hybrid thing with an NG (10v NA, 1988-1991) bottom end bolted to the 20v head, and then tune. The CIS is said to be good for 300hp as well.
The 20v head and 10v NG block together will yield around a 7.5-8.0:1 CR, and the NG bottom end is strong enough to hold 300hp if you tune it carefully enough (maybe more, the rods and pistons are not up to Audi turbo standards). Of course you can replace these as well.
The MCII should be able to make 300hp easily with either standalone EFI (and stock ignition with a chip), or carefully tuned CIS .
A 10vt is nearly indestructable, only limited on power by the fueling system, turbo, and the head. Motorgeek, is the place to get into the go fast options for the 10vt or other audi setups.
OTHER POSSIBILITIES 20v 4cyl DETAILED PICS
http://www.eclubvw.com/forums/showthread.php?s=9bf9594a49b82fc76b82f168da282c58&t=3385
VAG ENGINE INFO
http://www.eclubvw.com/forums/showthread.php?t=3139
20v 4 build up:
http://www.race101.com/project_2020.html
http://www.audi.com/audi/com/en1/glossary/biturbo.html
ONE OF MY FAVORITE AUDI SITES:
http://80tq.com/engine.html |
moone924
Posted: Fri Jan 20, 2006 6:44 pm Post subject: |
I have a nice NG short block for sale too Keaton.... _________________ Ryan Moone
