larso Guest
Posted: Wed Apr 24, 2002 6:21 pm Post subject: |
For anyone who needs to replace their clutch slave cyl, the haynes manual says:
Perform all steps necessary to remove the clutch and bellhousing in order to replace the slave cylinder.
Hrm. That would be terrible if you had to change the clutch disc and remove the bellhousing in order to change the slave! For me it was life or death since I needed the car in a day. Clutch jobs usually take 2 days minimum, or 2 weeks if you have any bolts that get stuck, correct? Anyway luckily the Haynes was wrong again.
This is worse than the place in the haynes where it says;
"Place the car on jack stands in order to reset the OXS warning light".
Ha Ha Ha.
Somewhere in this manual it must say that it is mandatory to remove the left rear wheel before checking your engine oil. Is it also mandatory that one lifts his left leg and hop like a donkey when filling the car with gas? I don't know about you, but I do.
If following the haynes, the valve lash settings and torque specs will cause serious damage to your engine, and the instructions will cause you to spend days working on the car.
I can not believe how all these mistakes entered this manual. The bottom line is that if the manual got revised it WOULD be a great manual to have.
[ This Message was edited by: larso on 2002-04-24 18:27 ] |
Joes924 Guest
Posted: Thu Apr 25, 2002 6:27 pm Post subject: |
Try to think things things thru,make sure its the best or rite decision & follow instructions..Like I dont really want this used header to burn up on me,I hope it wont
it was a good deal tho, Maybe Ill reinforce weld itaround the mounts to add strength..
Back to thread: Dont reuse what you shouldnt
and dont be cheap if Buying fasteners what do you do go to the fastner distrib. the source.[min amount of$$ per order] or who he distribs to KNECTS auto parts is best choice or even worse a shop maybe there youll definatly not go the cheap way.Unless your dads the owner
or theres no mark up cause you respect the owner &like his 356 hes builden even tho he likes hamms beer,
Theres 3 lessons to head in there somwwhere.
Joes924 Guest
Posted: Thu Apr 25, 2002 6:30 pm Post subject: |
My haynes needs a rebuild syptoms are curled pages like ancient seascrolls gonna sleeve emin plastic soon..yessir:???: Thats been buggen me
