Headers
Paul T.
PostPosted: Wed Feb 13, 2002 1:39 pm    Post subject: Reply with quote
I'm getting ready to order my headers and I need to know if I should have them ceramic coated or wrap them. I think ceramic coating is better, but I wasn't too sure about cracking. I won't be driving this car too hard anyway. And in case you're wondering, I was going to order them from MSDS. Thanks folks.
PostPosted: Wed Feb 13, 2002 11:40 pm    Post subject: Reply with quote
Definitely ceramic coat - wrap will promote rust and rotting out. Ceramic can crack, but it's still far better. That's what I've got, on my MSDS header, and love it!
PostPosted: Thu Feb 14, 2002 8:38 am    Post subject: Reply with quote
if you go for ceramic coating I recently read that if you want it to last the only colour to get is black.
Apparently the additives in the coloured stuff causes it to expand and contract at a different rate and it eventually flakes off. The "chrome" look stuff is supposed to be the worst.
This was from a guy who owns a business specialising in metal coatings so it's probably good advice.
Paul T.
PostPosted: Thu Feb 14, 2002 9:52 am    Post subject: Reply with quote
OK, I will use black ceramic coating. Now, my next question, I will be running steel braided oil lines to a remote filter mount and cooler, will I need to shield these around the header area or will the ceramic coating provide enough protection for these lines? Thanks Folks.
AznDrgn
PostPosted: Thu Feb 14, 2002 10:26 pm    Post subject: Reply with quote
I would say shield them it will only take you a few minutes to do it and better safe than sorry.
PostPosted: Fri Feb 15, 2002 12:47 am    Post subject: Reply with quote
Yes, an extra wrap of aluminized insulation would be highly adviseable.
Joes924
PostPosted: Sun Feb 17, 2002 11:00 am    Post subject: Reply with quote
theres heat wrapds to be used on plug wires they might fit .. I doute it though.
PostPosted: Mon Feb 18, 2002 11:43 pm    Post subject: Reply with quote
Depends on the size hose used, but I'd suggest using a sheet of wrap material secured with hose clamps; easier to remove for service.
Raymond D. Rheinbolt
PostPosted: Wed Apr 24, 2002 2:31 pm    Post subject: Reply with quote
Just stop in at Tweeks on Monday,
to look at their header, Made by
Boush, It is made with good material,
heavy pipe nice! 189.00
Nice unite!
Ray
Joes924
PostPosted: Thu May 02, 2002 3:11 pm    Post subject: Reply with quote
I here that a header causes wires to burn up if there not insulated &if you drive on the highway for a hour or two then look under the hood theres a cherry glow from the header
best to wrap that header or ceramic coat it.
Cbass
PostPosted: Thu May 02, 2002 6:10 pm    Post subject: Reply with quote
Depending on how you drive, the headers glow all the time
I strongly advise the ceramic, especially if it is a new header. It'll prolong the life of the header, and other things under your hood. Your engine will also run a bit cooler, and you get a little power as well.
Joes924
PostPosted: Mon May 06, 2002 1:56 pm    Post subject: Reply with quote
Found a bunch of places on the web that do ceramic coating work, there even a way to do it yourself it involves an oven though capablr of sustained 500 degree temp.look in general discussions ceramic coating.
