AC Question
awilson40
Guest
PostPosted: Tue Apr 23, 2002 5:38 am    Post subject: Reply with quote
hey guys...anyone know how the 'rotary temp'knob on the AC works??. My AC kicksout cold air but nothing happens when I turn the knob full cw or ccw??
Thanks
Guest
PostPosted: Tue Apr 23, 2002 6:08 am    Post subject: Reply with quote
I believe that's part of a thermostatic control for the ac and works in concert with a temp sensor that's attached to the fins on the ac evaporator under the dash. Clockwise should give max cooling. I don't really notice any difference when I change the setting on mine either. I don't think it can be changing the temp of the evaporator in a gradual way though. It should be just switching the compressor on and off, leaving it on longer when the knob is turned more clockwise.
'82 924 Turbo, Home Depot boost control, blue windshield washer fluid water injectio
[ This Message was edited by: Smoothie on 2002-04-23 06:11 ]
numbers
Guest
PostPosted: Tue Apr 23, 2002 7:41 am    Post subject: Reply with quote
Smoothie's got it. The outer rotary nob controls the temperature by turning the compressor on and off. All the way clockwise, full air, all the way counter clockwise, no air. I usually run mine about half way once the interior is cooled off.
