air/fuel ratio for the NA
augidog
PostPosted: Sun Jul 24, 2005 5:52 am    Post subject: air/fuel ratio for the NA Reply with quote
I awaiting my air/fuel gauge for installation.
I'm just gathering some info for the na so I can use it to its full potential.
Sounds like fun.
What is the air/fuel ratio and lambda ?
For petrol engines the air/fuel ratio is very important. It is the quantity of air aspirated by the engine against the quantity of fuel aspirated (carburettor) or injected (injection).
Lambda is a unit less number that gives you an indication of the air/fuel ratio. A lambda sensor measure the quantity of oxygen in the exhaust. A complete combustion didn't left oxygen at all. In that way the sensor can tell to us or to the engine management system that the engine runs rich or poor an let allow the ECU to make corrections if necessary.
The normal lambda sensor has a hysteretic characteristic between 0,9 and 1,1. Now we have also wideband lambda sensors which have a linear characteristic between lambda 0,7 to 1,2. This is the ideal sensor for tuning.
* The ideal air/fuel ratio for minimum consumption is nearly 15,4 kg of air against 1 kg of fuel (lambda 1,05)
* The ideal air/fuel ratio for maximum power is 13,2 kg of air against 1kg of fuel (lambda 0,9)
* The car manufactures admitted the norm of lambda 1 as 14,7 kg air against 1 kg of fuel. This is between minimum economy and maximum power
So if we search maximum power we have to see that the lambda is 0,9 at that point for an atmospheric engine. A turbo- or a supercharged engine has to run richer (at lambda 0,82) only for safety reasons, because the higher pressure and the higher exhaust temperature can destroy the engine. By making the mixture richer we cool the temperature in the combustion room and the exhaust to protect the engine.
13.2 wot and 15.4 idle is what I'm going to be looking for on the meter.
I'm wondering if this is possible with just the fuel mix or will I be getting into bigger injectors,larger throttle body,better performance air filter,etc?
I can't wait to tweak.
MunkPuppy
PostPosted: Sun Jul 24, 2005 11:51 am    Post subject: Reply with quote
are you using a wide-band O2 sensor or a narrowband O2? With narrowband, you're only going to be able to tell ifyou're rich or lean, no in-between readings, unfortunately
'80 931 FOR SALE
"It's a shame that stupidity isn't painful"
-Anton Szandor LaVey
augidog
PostPosted: Mon Jul 25, 2005 12:44 am    Post subject: Reply with quote
before my blazer went down I put in a new o2 sensor thinking that was the problem.I just pulled it from the yard where it was sitting. Its a wide band heated bosche
Raceboy
PostPosted: Mon Jul 25, 2005 2:16 am    Post subject: Reply with quote
Does it have 5 wires? In that case you'll need special box that controls the heating if it and displays numbers. You can do it yourself, but it's not an easy task (couple of printed circuit boards + parts + soldering)
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
endwrench
PostPosted: Mon Jul 25, 2005 6:51 am    Post subject: Reply with quote
No GM product has ever come with a wide band O2.
Todd
augidog
PostPosted: Tue Aug 02, 2005 10:16 am    Post subject: Reply with quote
Todd
Yea, he is right it’s just a heated sensor. I did a quick test with it in the muffler to check the gauge. It worked fine. But I was running really rich. I turned back at least 3/4 to idle at 14.9. This morning I ran it to work. What a difference!!!!! Even though it was not a wide band O2 it really helped with the overall performance especially on hills.
I can't wait to get it installed. As far as a tuning tool it is one of the best investments I made. Anyone running a early NA without a O2 sensor will definitely benefit from the info it gives. That 3/4 turns made no difference in rpm or vacuum but on the road it was proven results.
J1NX3D
PostPosted: Tue Aug 02, 2005 5:28 pm    Post subject: Reply with quote
sounds awesome!!
im getting one of these guages:
Autoguage air fuel gauges are of a very high standard and half the price of competing similar products a big bonus
Product Specifications : Part Number: AFRLED-20W
1 x Air Gauge
1 x Fitting instructions
Optional Mounting cup chrome or black can be purchased for $10.00 with the gauge unit .
Requirements :
The gauge must be wired to your factory oxygen ( O2 sensor) or an after market one. Instructions state it can be wired to the following :
1 Wire Sensor (Non Heated)
2 Wire Sensor (Non Heated)
3 Wire Sensors (Heated)
4 Wire Sensors ( Heated).
Gauge Readings:
The gauge has 20 LED to read between 50 mv up to 1.000 Mv. Range indication is as follows:
Lean ( 4 LEDs) .050 to .249 mv
Optimal ( 10 LEDs) .250 to .749 mv
Rich (6 LED) .750 to 1.000 mv
what sensor would you guys recommend?
and would i need something like this?
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Electronics/auction-32339612.htm
'86 944
jpab924
Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
PostPosted: Fri Nov 04, 2005 2:57 pm    Post subject: Reply with quote
I bought an a-pillar pod to put in my 924 turbo.
I`m looking at air/fuel guages. The autometer website says that their guage will work with most narrow band 02 sensors.
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=2606
Can anyone confirm that the narrow band sensor in my 924 turbo will work with this guage? Or will I need to buy their acc. kit?
http://www.autometer.com/cat_accessoriesdetail.aspx?vid=162
I`d to opt for a wide band setup...but for 500.00 its past my budget.
PostPosted: Sat Nov 05, 2005 2:22 am    Post subject: Reply with quote
Unless there's an oddball sensor out there somewhere that I don't know about, any narrow band o2 sensor will work with any narrow band air:fuel gauge. They're all the same as far as chemical reaction and electrical output.
I have the one Bosch o2 sensor in its' OE position and wire to the OE connector and wire below-behind the crossmember that then runs on up to the Lambda box under the dash. I tapped a second single-conductor wire in between the crossmember connector and o2 sensor (so it can be unplugged from the Lambda box, but remain connected to the gauge for testing). Some say you should have a second o2 sensor for the gauge, but I'm using just one with no apparent dysfunction (car runs fine and the gauge reads just as it should under different conditions - idle, part throttle, WOT, etc.).
If you're fussy, you could use a shielded wire from sensor to gauge like Porsche used from sensor to Lambda box.
jpab924
PostPosted: Sat Nov 05, 2005 5:21 am    Post subject: Reply with quote
Ok Smoothie, just wanted to be sure the Porsche 02 wasn`t one of those "oddball" sensors.
I have the 02 sensor unplugged from the system now. Engine runs a whole lot better without it.
I was going to just tee off somewhere in the cabin of the car close to the lambda box.
PostPosted: Sat Nov 05, 2005 8:17 am    Post subject: Reply with quote
Well it might actually be easier to T-in where I described because there's a short length of single-conductor wire there that's easy to tap in to. The rest of the wire from cross-member connector to lambda box is a coaxial shielded wire.
jpab924
PostPosted: Sat Nov 05, 2005 1:11 pm    Post subject: Reply with quote
Ok I gotcha now.
I`ll prod and poke when I`m ready....but your advice is solid.
augidog
PostPosted: Sun Nov 06, 2005 12:05 am    Post subject: Reply with quote
$19.00 O2 SENSOR
My used one stopped sending voltage,it was all blackened from the my Chevy Blazer it came from with a leaking fuel spider.
I would not get a heated again.
The wires already melted together and shorted out causing a toaster effect on the highway,also frying my voltage regulator and toasting the chip in the gauge.
With everything now replaced I'm looking forward to tuning again. It was amazing the immediate response felt in the engine to tuning to the sensor's read out. I was running very rich and the adjustment in the mix can be as little as an 1/8th turn on the allen.
https://www.automedicsupply.com/catalog4.php?#
ryoji
PostPosted: Tue Nov 08, 2005 12:48 am    Post subject: Reply with quote
I used this for the race car. It shows ratio instead of pre-programmed arb. light.
If you want to buy : http://www.cbperformance.com/catalog.asp?ProductID=598
However, I thought CIS keeps the ratio pretty much the same for all range of usable RPM, as well as the degree of the pedal you press.
R.I.P.:a 924 ITA race car
View user's profile Send private message Visit poster's website AIM Address
augidog
PostPosted: Tue Nov 08, 2005 9:41 am    Post subject: Reply with quote
Yes I've heard this also. but the air/ fuel mix still seems to vary.
I've read that the best tuning area for air/fuel should be at 3800 rpm -probally at cruise. I can't wait to get it testing again.
