avalanche Guest
Posted: Fri Mar 22, 2002 8:49 pm Post subject: |
hello everyboby,
Does anyone know how to test the cold start valve on a 924,is it a cintnuity test, what voltage/impedances should be seen if ok/faulty,
Ryan
dpw928 Guest
Posted: Sun Mar 24, 2002 3:19 am Post subject: |
The only test it lists in my Haynes or FI manual is a physical check of the spray pattern. Resistance reading aren't provided. I would check each post to ground to confirm there is no short within the valve.
Dennis |
Roger Hall Guest
Posted: Tue Mar 26, 2002 12:20 pm Post subject: |
| the only test are phyisical is it leaking and the spray pattern but if it is not working check the voltage supply from the thermo time switch while the engine is cold pull the connector and attachc a voltmeeter turn on the ignition you should have a voltage reading and it should drop to zero within 10 seconds |
