compression readings!
levans924
PostPosted: Sat Mar 23, 2002 3:19 am    Post subject: Reply with quote
i just purchased a 78 924 but before i bought it had a compression test done.
these were the results
1-170
2-173
3-169
4-175
is this good?
numbers
PostPosted: Sat Mar 23, 2002 3:22 am    Post subject: Reply with quote
Very.
PostPosted: Sat Mar 23, 2002 3:24 am    Post subject: Reply with quote
I'd say it's very good that the numbers are so close to one another - small percentage of difference between cylinders. Not sure if they're a little high though - maybe indicating some carbon build up? (REALLY not sure about that, so; don't worry about it - they're probably just real good numbers.)
[ This Message was edited by: Smoothie on 2002-03-23 04:41 ]
Cbass
PostPosted: Sat Mar 23, 2002 3:36 am    Post subject: Reply with quote
Those are quite high indeed. Ask the previous owner what sort of work was done to the engine.
PostPosted: Sat Mar 23, 2002 3:48 am    Post subject: Reply with quote
If you do ask the previous owner - also ask (if the head was off) what part # head gasket was used. I realise this might be an obscure question, but; he might just happen to know. A thinner head gasket might account for higher compression readings.
[ This Message was edited by: Smoothie on 2002-03-23 04:49 ]
ricomartinez
PostPosted: Sat Mar 23, 2002 5:31 am    Post subject: Reply with quote
Yeah, if everything is stock, I'd either just be happy they are so close or get another gauge to very the first gauge is good.
PostPosted: Sat Mar 23, 2002 6:23 am    Post subject: Reply with quote
Somewhere over the years I read that it's ok to have high readings - most important is that they all be about equal (within something like 10% of each other). Might just be getting a few more HP out of it. If detonation is a problem, as can happen with higher compression, try higher octane gas. If detonation is still a problem and the high compression is due to carbon buildup, there are ways to get some of that out without dismantling the engine.
[ This Message was edited by: Smoothie on 2002-03-23 10:30 ]
Cbass
PostPosted: Sat Mar 23, 2002 9:20 am    Post subject: Reply with quote
Try using 87 octane gas. Punch the throttle, release quickly, run at high rpm, the usual. If you get any significant detonation, then you know you have high compression.
PostPosted: Sat Mar 23, 2002 10:09 am    Post subject: Reply with quote
levans924 -
Is that a US spec car, Europe or something completely different?
Roger Hall
PostPosted: Sat Mar 23, 2002 11:48 am    Post subject: Reply with quote
rejoice and be happy
those are great readings
