924-944 ENGINE CONVERSION...CROSSMEMBER AND ENGINE MOUNTS
simsport
PostPosted: Tue Nov 02, 2004 4:47 am    Post subject: 924-944 ENGINE CONVERSION...CROSSMEMBER AND ENGINE MOUNTS Reply with quote
Always open to new possibilites I may be able to drum up a 944S2 engine, which, like my 924 I would like to supercharge.
Wanting the best of both worlds I wondered if anyone has ever produced an adaptor or kit that might allow the engine crossmember or mounts for a 944 to fit to a 924 steel crossmember?
Thus I could use the 944S2 engine and keep my chassis able to take the 924 engine also.
Cheers
Simon
Blown is always best!
gohim
PostPosted: Fri Nov 05, 2004 12:22 am    Post subject: Reply with quote
Porsche redesigned the way that the engine is located and mounted on the 924S and 944 when teh change was made from the 2.0L 924 engine.
The two ways to mount a 944 engine in a 924 is either to cut the chassis moutning points from a salvage 944 or 924S, or modify a spare 924 crossmember to support the 944 engine mounts.
The radiator support is also relocated farther forward in a 924S/944 and you will have to deal with that issue as well.
felony4th
PostPosted: Thu Nov 11, 2004 12:04 pm    Post subject: madness Reply with quote
gohim, you are CRAZY!!
This forum should have an awards ceremony.
keep it up, man.
bk
