Rats - Head Gasket
MaV
PostPosted: Fri Oct 31, 2003 5:17 am    Post subject: Rats - Head Gasket Reply with quote
Oh well, had to happen. Knew something was wrong when it sucked 4 litres of coolant the other day...
Incidentally, cam oiler tube had snapped off after number 3, might explain the mysterious 0.5 - 1 bar drop in oil pressure
Who's a good (cheap!) source for parts in the UK? Usually use Berlyn (excellent) but could do with a second source.
Cheers from the driving seat of the Volvo for now.
1982 931. 'Nuff said
MaV
PostPosted: Mon Nov 17, 2003 5:26 am    Post subject: Reply with quote
Cool, no material damage to head or block it seems. General clean-up/flush, check head for level and new gaskets should do it.
Phew
PostPosted: Mon Nov 17, 2003 5:29 am    Post subject: Reply with quote
good to hear
3 928s,
MaV
PostPosted: Mon Nov 17, 2003 6:21 am    Post subject: Reply with quote
Thanx. Needed some luck along the line!
MaV
PostPosted: Mon Nov 17, 2003 6:49 am    Post subject: Reply with quote
As an observation. If your turbo is sound, leave it where it is.
Once the exhaust was out of the way I had easy access to the 3rd turbo/manifold flange bolt with a deep offset closed wrench - 1/8th turn at a time but good enough The J pipe wasn't that big a deal but cost me a 1/2 - 3/8 adapter before they let go at the top!
PostPosted: Mon Nov 17, 2003 7:12 am    Post subject: Reply with quote
I have replace the turbo while engine in the car and I didnt find it that difficlut, I came at it from below, but I did remove the oil cooler lines and I was able to break it free with a wrench, once use I used a stubby ratchet and it came off easily
3 928s,
MaV
PostPosted: Sat Nov 22, 2003 8:15 pm    Post subject: Reply with quote
Read in the Haynes that the 12 point head bolts don't need re-torquing after 1000 miles. Is this correct? And should I replace the head bolts with new? Also, should the final 180 deg. be applied in one go or incrementally?
Cheers
wdb
PostPosted: Sun Nov 23, 2003 2:50 am    Post subject: Reply with quote
there may be some useful info here
http://www.asashop.org/autoinc/aug2003/techtotech.cfm
Use an accurate torque wrench to tighten standard type head bolts in 3 to 5 incremental steps following the recommended sequence and torque specs for the application. Tightening the bolts down gradually creates an even clamping force on the gasket and reduces head distortion
PostPosted: Sun Nov 23, 2003 8:50 am    Post subject: Reply with quote
Cheers
If you can get past the cost, the best thing you can do regarding head bolts is to install Raceware studs. No more retorquing!
http://www.raceware-fasteners.com/prod01.htm
MaV
PostPosted: Thu Nov 27, 2003 2:14 am    Post subject: Reply with quote
Thanks for the links Guys. What I really wanted to know is whether the 12 point "stretch" bolts can be reused or if they should be replaced when changing the head gasket - I'm guessing replacement...
Cheers
PostPosted: Thu Nov 27, 2003 3:31 am    Post subject: Reply with quote
No they generally can be reused
as the torque is not that high
that the bolts will be limited
unless you do it a bunch
of times and it fails on you
again...
