Board Speed
Post new topic   Reply to topic    924Board.org Forum Index -> About The Board
PostPosted: Mon Jul 30, 2001 1:55 am    Post subject: Reply with quote
would you guys give me an indication of the speed of the discussion board from where you are and how you're connected to the Internet.
Stuff like "I've got a cable connection and it takes 5 minutes to load, I'm in Alabama" or "I'm in Paris on the end of a 32K modem and it's no slower that anything else" will help.
Thanks.
PostPosted: Mon Jul 30, 2001 2:08 am    Post subject: Reply with quote
Wayyyyll... I'm in Detroit on a cable modem, and seeing no problems with speed; it's loading as fast as anything else right now... certainly not seeing any impact due to the pages coming from OZ, which I was a little concerned about... I think really this layout only speeds access compared to the old board, due to not having to load one big huge long index page...
Nicke
PostPosted: Mon Jul 30, 2001 2:14 am    Post subject: Reply with quote
Loading very fast here in Finland via cable. Good job, guys.
bacook
PostPosted: Mon Jul 30, 2001 2:26 am    Post subject: Reply with quote
All good in Austin using a cable modem.
RobE
PostPosted: Mon Jul 30, 2001 2:47 am    Post subject: Reply with quote
No problems here. I still on the ancient dial up connected at 41000kps. Seems to load faster than the old one. Good job guys. Oh I'm in Colorado. Rob E.
kevrl
PostPosted: Mon Jul 30, 2001 3:52 am    Post subject: Reply with quote
Hello,
I'm in the UK (Essex) on a 56K Modem and this board loads up MUCH quicker than the old one, it will be interesting to see if its still quicker when there's a load more posts on it.
Kevin
swicks
PostPosted: Mon Jul 30, 2001 4:43 am    Post subject: Reply with quote
No problems from a cold South Africa - I'm on an isdn line, but I prefer the old site!
AppleBit
PostPosted: Mon Jul 30, 2001 5:05 pm    Post subject: Reply with quote
I think if I went back to moris code setup through wire it still would have been faster than the old board
I'm in MN with a 56k wireless internet setup (modem) and see only speed...
Now, the question is.. do I think the new message board is kewl? __YES__!!
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
Paul T.
PostPosted: Wed Aug 01, 2001 3:57 am    Post subject: Reply with quote
Board speed is KICKIN'! It will take some getting used to, but it seems OK.
JimmyTheD
PostPosted: Thu Aug 02, 2001 1:18 am    Post subject: Reply with quote
I'm in Charlotte NC US, working off a corporate LAN firewall in NYC. No problems with speed. Board really loads fast...!!
Thanks
Ciao
Jimmy
D Hook
PostPosted: Thu Aug 02, 2001 9:47 pm    Post subject: Reply with quote
Using a cable modem in Omaha NE and it works great. Nice work guys!
larso
PostPosted: Fri Aug 03, 2001 11:56 am    Post subject: Reply with quote
56K modem Edmonton Alberta Canada faster than rennlist online boards, faster than pelican.
numbers
PostPosted: Sat Aug 04, 2001 9:14 am    Post subject: Reply with quote
I am on a T-1 in Denver CO. Great Speed.
Rick MacLaren
PostPosted: Fri Aug 24, 2001 12:25 am    Post subject: Reply with quote
T1 in Waterloo Ontario and it's as slow as Lars' car.
Post new topic   Reply to topic    924Board.org Forum Index -> About The Board All times are GMT + 11 Hours
