931 to 937
Peter
PostPosted: Tue May 06, 2003 12:43 pm    Post subject: 931 to 937 Reply with quote
The latest issue of 9 Magazine has a 2 page spread of a man who coverted his 931 to a 937 replica, with 937 intercooler, flares, headlights, interior --the whole package. Some nice picks of cutting the rear quater panels, and other fabrication he did. Good issue to buy and save.
Strange how these people are not on this board?
-Peter
PS the latest issue of GRM has some interesting articles on dyno's, how to read them, how not to be fooled by high HP numbers, etc. Another good issue to buy and keep
sandgroper
PostPosted: Mon Jul 14, 2003 4:01 am    Post subject: Reply with quote
peter,is it the may issue,i would like to get it,thanks
epsylon
PostPosted: Mon Jul 14, 2003 6:23 am    Post subject: Reply with quote
yes, i would love to see the article as well. anyone have the issue and a scanner? we could easily find a place to host the pictures for people to review and read.
'82 931
'78 928
Howell Henderson
South Padre Island
PostPosted: Mon Jul 14, 2003 6:33 am    Post subject: Reply with quote
hey epsylon, is your distributor sitting properly, it looks like it might be sitting to high, IE mounted on wrong holes. if it is sitting like this the cap will hit the hood
3 928s,
924 turbo
PostPosted: Mon Jul 14, 2003 8:46 am    Post subject: Reply with quote
Ditto what Lizard says. Good eye, Lizard!
Jon Furst
epsylon
PostPosted: Mon Jul 14, 2003 11:17 am    Post subject: Reply with quote
yes either the PO or his mechanic mounted it wrong 180 degrees and it does just barely hit the hood. i have not had time to mess with it. it does not effect drivability that i am aware of. i just have to be carefull when closing the hood.
'82 931
'78 928
Howell Henderson
South Padre Island
PostPosted: Mon Jul 14, 2003 12:46 pm    Post subject: Reply with quote
let me put it this way, CHANGE IT NOW, the hood will hit it and break the spark plug wire and the cap, one day you will go to start it and it wont start, then you will open the hood to see what is wrong and you might spot it right away you might not, but it will casue the car not to start or run REALLY poorley, so do it now so you don't have to worry about it.
3 928s,
epsylon
PostPosted: Wed Jul 16, 2003 1:29 am    Post subject: Reply with quote
i will try and get to it this weekend. relocating the distributor means ordering a new valve cover gasket which was why i havn't messed with it yet.
let me make sure i understand what needs to be done though. it is mounted in the wrong mounting holes seating it too high and not the 180 degrees out of phase that is cuasing it to almost hit the hood, correct?
'82 931
'78 928
Howell Henderson
South Padre Island
PostPosted: Wed Jul 16, 2003 3:07 am    Post subject: Reply with quote
basically you undo and remove 3 bolts, you then slide it back take of the old gasket lay the new one down put it back on andput the bolts in the right holes this time and screw down, dont over tighten aluminum head will strip easy. but with it in its current position, it is probably hitting the hood, unless your hood is siting alittle high.
3 928s,
epsylon
PostPosted: Fri Jul 18, 2003 1:33 am    Post subject: Reply with quote
gee thanks. you made me look really lazy.
'82 931
'78 928
Howell Henderson
South Padre Island
78porsche924
PostPosted: Sat Jul 26, 2003 6:48 am    Post subject: Reply with quote
Also vaughn mentioned some people haveing problems of the spark plug wires arcing to the hood when it is in the right spot. You might be having this with the dizzy toughing the hood.
90 944 S2
78 924 NA <---now sold and killed by new owner
snailshell trans
Bae turbo kit
to check out my 944 S2 http://www.cardomain.com/member_pages/view_page.pl?page_id=388139
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger
PostPosted: Sat Jul 26, 2003 7:35 am    Post subject: Reply with quote
Whats with the metal cup around the cap,I picked one up from an 80
Also the bolts are ruff to get to on the dizzy mount. Ijust picked the p .excellence mag with the US lega redl 959 the cover.Whats the address for nine mag. So I can pick up a sub. wasnt someone from the board
involved with the mag I remember reading about it. awhileback on this here board. Pm me the address for a sub. I cant find it around here I dont think. Sound s like agood article .
sandgroper
PostPosted: Mon Jul 28, 2003 2:56 am    Post subject: Reply with quote
good news,go to www.9magazine.com and order back issue vol2 no1,$5.99.
TonD
PostPosted: Thu Jul 31, 2003 2:53 am    Post subject: Reply with quote
USA orders only So, the search for someone with the magazine AND a scannner continues
Just remember I aint American nor English, so please don't blame my language
J1NX3D
PostPosted: Tue Aug 05, 2003 7:02 am    Post subject: Reply with quote
im keen to have a look also. there are interior differences between 931/ 937? what are they?
'86 944
